  4. Some issues and questions
12 Posts 3 Posters 116 Views
  • MyRoute-app community Offline
    Administrator
    Hi Jörgen, it appears that you're not using MRA Navigation Next. You're using the default 'follow the line' mode.
    When searching for a location, instead of generating a route, select the tap-bar to switch to Navigation Mode. As @Corjan-Meijerink pointed out in a different thread, we've opted to keep the current Mobile route generator in there as well.
    • Jörgen Offline
      Jörgen Offline
      Ok, understand. User Error! 😖
      • Jörgen Offline
        Jörgen Offline
        @Timo-Martosatiman-MRA said in Some issues and questions:
        Sorry I do not understand "When searching for a location, instead of generating a route, select the tap-bar to switch to Navigation Mode"
        I can´t get it to work.
        When I search for a location with the lupe and found it.
        What is to do next to get the right navigation mode?
          @Jörgen Thanks for your reply.
          Navigation Next is still being developed for CarPlay. This is therefore indeed not accessible yet.
          Regarding your screenshots, you are navigating using the Mobile app and not with the Navigation module. When opening a route, select the most right button in the row containing 4 buttons. This one contains a white Navigation arrow icon.
          Corjan Meijerink Offline
          @Jörgen Please see below. This applies for opening a route.
          @Corjan-Meijerink said in Some issues and questions:
          When creating / finding a route, using the search functionality (magnifying glass, top right), you can use the original Mobile generator or start Navigation Next. Select the right tab and click on generate, see the attached image.
          • Jörgen Offline
            Jörgen Offline
            Ok, that worked now.
            But I noticed other issues.
            1. The iPhone goes in sleep mode (or what is it called) with and without power connection during navigation.
            2. There is one strange German word (that not exist) every time before a meter indication is made in the voice command. e.g., ( nach xxxx 300 Meter) I do not understand this word.*
            3. The Car Radio sound is interrupted during each voice command and will not come back.
            • I will try to record this. Is it possible to make a record on iPhone with sound?
              @Jörgen Happy to hear that it worked! Issues 1/3 have been reported before too 🙂
              Regarding number 3, does this also happen with Spotify / Apple Music? Or just radio? Is audio playing over bluetooth or with CarPlay?
              I’ll take a look at 2. The instructions are directly provided by HERE without any interference by us. If you do hear what they say, please let me know 😉
              • Jörgen Offline
                Jörgen Offline
                Oh, late work.
                I do not use Spotify / Apple Music only DAB Radio. The old MRA Naivgation App had the same problem. I thing it was discussed already. Even when a speed alarm came, the radio sound goes off. Then need to touch the Radio button to get sound back. Voice commands are coming via USB connected iPhone (Car play)
                I will try to record this wording.
                • Jörgen Offline
                  Jörgen Offline
                  In addition, I think there should be a clear indication if I am in the planing mode or in navigation mode.
                  Without your hint, I did not find or know how to start navigation.
                    @Jörgen Yes, that will be improved 🙂
                      Oh, late work.
                      @Jörgen Thanks for letting me know, I think the issue is related to radio in that case. If you at any point do use another music player, do let me know if the issue also occurs.
                      I wasn't able to test this as my car doesn't allow Radio & phone audio at the same time. The issue has been reported by others and will be investigated! 🙂
                      • MyRoute-app community MyRoute-app community moved this topic from [Beta] The MyRoute-app on
                      • Paar onduidelijkheden.
                      • Route app reageert niet
                        Erik Schouten
                        Erik Schouten
                        Huibertus
                        Huibertus
                        7.0k
