  4. Suggestions
Suggestions
45 Posts 22 Posters 489 Views 3 Watching
  • Tim  Thompson
    Tim  Thompson
    Tim Thompson
    I've made suggestions about hiding shaping points in the General Discussion forum...
    Hide shaping points
    My comments there...
    @Tim-Thompson said in Hide shaping points:
    It might be nice to be able to turn/off or filter the shaping points from view - especially in MRA Navigation. If you have to import a route (via GPX or otherwise), you might have to have a fair number of shaping points to faithfully recreate the desired route. However, once the shaping points have done their job, one doesn't necessarily need to see them - especially when navigating.
    I'm aware that waypoints can be colored. However, that's not what I'm after. I would like to be able to make the shaping points disappear. In most cases I don't need to see them while navigating. I would rather not see distance to next shaping point (this can be annoying - especially when you have to have many shaping points whose only purpose is to get the app to faithfully plot the intended route). Instead I would like to only see distance to the next turn or stop. Either make all shaping points visible/invisible as a whole, or maybe - like being able to set their colors - be able to set the visibility of waypoints individually.
    I think it would also be helpful the be able to hide the shaping points in the route editors - so that the route display can be decluttered and the important things can better be brought into focus.
      šŸ‡³šŸ‡± Plaats random 'suggesties' in losse topics, zo kunnen we ze taggen en later nog eens bekijken. Ook houden we zo de discussies 'on topic' per suggestie! hou er rekening mee dat we tot 1 juni 2023 een strakke planning hebben. Maar daarna is er weer van alles mogelijk, dus hou je vooral niet in!
      šŸ‡¬šŸ‡§ Place random 'suggestions' in seperate topics, that way we can tag them and keep them marked for later use. That way, every suggestion has it's own 'on topic' discussion! keep in mind that we have a tight schedule until June 1, 2023. But after that, anything is possible again, so don't hold back!
      EDIT 05/09 by Timo:
      Locked topic and edited rules so that suggestions are posted in seperate topics.
      TJ189
      TJ189
      TJ189
      @Michel-van-Hagen-MRA-Founder
      You may wish to consider the use-ability of this app by a rider base of over 75000 members worldwide - the Iron Butt Association. There appears to be a great opportunity at this stage to reach out to that organisation regarding what may support their riders completing their rides and rallies.
      Shannon McDougall 0 1 Reply Last reply
      • TJ189 TJ189
        Shannon McDougall 0
        Shannon McDougall 0
        Shannon McDougall 0
        @TJ189 As an organiser of a long distance rally and a member of the Iron Butt Association, I agree. I have used a variety of different GPS solutions and none quite fit the purpose. It would be fantastic to have an app that was responsive to the needs that we have.
        • Dewi Siemerink
          Dewi Siemerink
          Dewi Siemerink
          It would be really useful to see others in your touring group as dots on the navigation screen so you can see if someone is falling behind or maybe went down.
          • MotoCon
            I surely hope that my 2 main frustrations will be addressed:
            • Selecting the waypoint to skip to is an inhumanitary task. Make the waypoint selectable from the screen instead of having to next, next, next, next, next, next, next, next, next, next, next, next, next, next, next, until WP 88 or so...
            • The option "start from nearest waypoint" does not stick. after loading a route, or restarting the app it defaults back to "start from beginning". This should be a systemwide option that sticks to what you tell it to do.
              EDIT 05/09 by Timo:
              Mopetenpit
              Mopetenpit
              Mopetenpit
              There are already some good suggestions and ideas listed here.
              Here is my contribution:
              Focus the development on motorbike navigation for the time being. The programmers will certainly take into account the needs of all the different methods of transport in the internal structures.
              Leave many settings to the user. I am thinking here of something like a "Config page" with True/False switches. Possibly with a basic and expert mode.
              One detail: in addition to the texts that a via/shaping point can contain, optionally send an acoustic signal - with N kilometres (or minutes) advance. Of course, a separate WAV file would also be possible... 😊
              Otherwise, I am looking forward to the further development of the NAV software. The new mobile app gives rise to great hopes.
              Peter
              • Herko ter Horst
                De enige manier (die ik op dit moment zie) waarop Next voor mijn gebruiksscenario's bruikbaar gaat zijn, is als de navigatie primair op basis van de in MRA Routeplanner (of andere software) uitgerekende route (gerepresenteerd in GPX als de track) plaats gaat vinden, zonder dat de app zelf gaat rekenen aan hoe de route moet gaan lopen.
                Als er van die route afgeweken wordt, zou het standaardgedrag m.i. moeten zijn om via de snelste weg terug te worden gestuurd naar de route (dit is dus dynamisch o.b.v. hoe ver je van de route afwijkt). Aangezien de route niet is berekend o.b.v. routepunten in deze situatie, is het overslaan van routepunten hierbij niet relevant.
                Routepunten (met name via-punten) zijn interessant voor stops e.d. dus zichtbaarheid/hoorbaarheid hiervan is belangrijk, ook als ze niet primair voor navigatie gebruikt worden. Hoe meer mogelijkheden er zijn om die zichtbaarheid/hoorbaarheid in te kunnen stellen (dus evt. ook uit te kunnen schakelen), hoe beter in mijn optiek.
                M.b.t. het halverwege starten van een route: het zou mooi zijn als je bij het openen van de route c.q. het starten van de navigatie, gevraagd wordt of je naar het startpunt, of naar het dichtstbijzijnde punt wilt rijden. Naar het dichtstbijzijnde punt is uiteraard gelijk als van de route afwijken en kan dus op dezelfde manier afgehandeld worden (via de snelste weg naar de dichtstbijzijnde plek op de route).
                Daarnaast zou het mooi zijn om op elk gewenst moment via de snelste weg naar een te kiezen routepunt te kunnen rijden, waarbij de geplande route dus wordt genegeerd.
                English:
                The only way I can currently see Next being suitable for my use cases, is when navigation is primarily based on the route as it has been calculated by MRA Routeplanner (or other software) (currently represented in GPX as the track), without the app recalculating what the route should be.
                When deviations from this route occur, the standard behaviour should be to direct the user back to the route by the fastest route (this should be dynamically calculated on the fly). As the route is not primarily based on waypoints, skipping them becomes irrelevant in this scenario.
                Waypoints (in particular via points) are still very relevant even when they are not used as the primary means of navigation, as they denote stops or other important points on the route, so they should be visible/audible during navigation. The more options users have to fine-tune the visibility/audibility of waypoints (to the point of turning them off completely), the better, in my opinion.
                With regards to starting halfway along the route, it would be nice if the app would ask the user whether they want to start at the beginning of route or at the nearest location on the route. This should then be handled in the same way as a deviation from the route, i.e. direct the user to the nearest location on the route in the fastest way.
                It would also be very nice to be able to drive to any route point in the fastest way at any time the user desires, ignoring the planned route.
                  English:
                  @Herko-ter-Horst Eigenlijk dus navigeren op basis van een track i.p.v. routepunten die je naar de app stuurt... toch? Pas dan weet je dat er geen extra berekeningen plaatsvinden. Gewoon de lijn volgen maar dan wel turn-by-turn.
                  šŸ’» Routelab on MacBook Air & iMac (Golden Gate & Ventura)
                  • Tim  Thompson
                    Tim  Thompson
                    Tim Thompson
                    If you want to know how Navigation or Next can be improved, I might suggest you look at the competition. Right now, when it comes to identifying actual worthy competition, I might suggest looking at Scenic. Do a head to head comparison identifying the strengths and weaknesses of each. When done, maybe areas where MRA Navigation/Next can be improved will be illuminated.
                    Scenic
                    Detailed Tutorial Video
                    One area that MRA Navigation scores a point is that it's available on both iOS and Android. However, if the Scenic website holds true, that advantage won't be long lived. They are supposed to be delivering an Android version of Scenic soon.
                    • Tim  Thompson Tim Thompson
                      Scenic
                      -In- en uitschakelbare functie voor automatisch herberekenen van de route.
                      -Mogelijkheid om bij een obstakel in de route een alternatieve routedeel te berekenen. Liefst met een keuze ten aanzien van de lengte van het alteratief.
                      -Switchable automatic route recalculation function.
                      -Possibility to calculate an alternative route section in the event of an obstacle in the route. Preferably with a choice regarding the length of the alternative.
                      • TorqueRider TorqueRider
                        #21
                        @Jack-van-Tilburg said in Suggestions:
                        Dit vind ik een sterk punt van mijn Garmin, zeker als ik per sƩ de ingestelde route wil volgen. Daar laat ik ook de track in een afwijkende kleur tonen tijdens het rijden. Als je van de route afwijkt, dan kan je op de kaart nog steeds de track zien (afhankelijk van het zoom-niveau).
                        • MotoCon
                          @Rob-Verhoeff said in Suggestions:
                          Feitelijk is het een lapmiddel om het volgen van een track in plaats van een route mogelijk te maken. Bij voldoende vertrouwen in een correcte route is het volledig overbodig. Aan de andere kant zou het wel publiek met een Garmin achtergrond kunnen overhalen šŸ˜‰
                            Nee. Je hebt ongelijk.
                            Als je niet herberekend blijft de route in beeld en heb je de track niet nodig.
                            En deze suggestie is niet voor niets gedaan samen met:
                              #24
                              @ Allen ben ik wellicht te ambitieus als ik zou willen voorstellen om te vragen om zowel de mogelijkheid te hebben met track als met route kunnen te kunnen navigeren hehe. Als de app beide kan en beide manieren perfect gaan, dan zijn alle partijen tevreden! šŸ™‚
                              Rob Verhoeff MyRoute-app community 2 Replies Last reply
                                @StefanHummelink for president 😁 šŸ‘
                                • Tim  Thompson
                                  Tim  Thompson
                                  Tim Thompson
                                  Should also note that the are on V3 of Scenic. The tutorial video was for V2.
                                  Scenic 3 Videos
                                  • Tim  Thompson
                                    Tim  Thompson
                                    Tim Thompson
                                    Here is something that I hope goes away in Next... The requirement to zoom in to see POIs (at least be able to disable it).
                                    Posted this suggestion in the General Discussion forum...
                                    Suggestion: Don't require zoom to see POIs
                                      @Michel-van-Hagen-MRA-Founder Niet zozeer random: maar ik zou in de eerste versie van februari toch al wel verwachten dat de nieuwe nav functie ook goed omgaat met "offroad" routepunten. De huidige app kan dat niet en dat is toch echt praktisch zeker wel een gemis. Hier komen op het forum zeer veel berichten van binnen.
                                      MC Highway
                                      MC Highway
                                      MC Highway
                                      @StefanHummelink Helemaal mee eens. Zeker het laden van een track die offroad navigatie mogelijk maakt zou dit een unieke app maken.
                                      • Tim  Thompson
                                        Tim  Thompson
                                        Tim Thompson
                                        #29
                                        Continuing the theme of finding inspiration by looking at the competition... I've been glancing through Scenic's documentation and videos. Thought I might jot down some difference that may be worth noting. If I note something that differs between the two apps, but there isn't really a difference - I just missed the feature in MRA Navigation - let me know.
                                        A couple of glaring differences... First, Scenic doesn't have it's own web based route/trip planner. However, it's not necessary really. Scenic's interoperability/integration with other planners (to include Furkot) makes it a minor point. Second, Scenic doesn't have any traffic capabilities. Advantage MRA Navigation.
                                        Settings:
                                        • Scenic has Show Compass on Map and Show Map Scale settings. Those might be handy. Points to Scenic.
                                        • Map Styles. Scenic allows you to select various. I don't know about anybody else, but when you zoom out a little bit on the map in MRA Navigation, you can't see any roads. Even when you are zoomed in, the roads can still be hard to see depending on the lighting (re. out in the sun). Having different map styles to improve readability might be handy.
                                        • Detour behavior. Scenic handles detours? Might be handy.
                                        • Scenic's Via Point Pro Mode. Allows user control of shaping point visibility. I've mentioned this before. Point to Scenic.
                                        That it's for the moment (the wife is after me). More to come later...
                                          EDIT 05/09 by Timo:
                                          Bergefall
                                          Bergefall
                                          Bergefall
                                          @Michel-van-Hagen-MRA-Founder would be great if you could include speed cameras in Europe.
                                          Mopetenpit
                                          Mopetenpit
                                          harmpert
                                          harmpert
                                          UltraStar
                                          UltraStar
                                          Steve Lynch
                                          Steve Lynch
                                          Shannon McDougall 0
                                          Shannon McDougall 0
                                          Tim  Thompson
                                          Tim Thompson
                                          TJ189
                                          TJ189
                                          Bergefall
                                          Bergefall
                                          MC Highway
                                          MC Highway
                                          Dewi Siemerink
                                          Dewi Siemerink
                                          Tunca Bergmen
                                          Tunca Bergmen
                                          HansK
                                          HansK
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
