  3. Use of basecamp
Use of basecamp
15 Posts 6 Posters 653 Views 1 Watching
  • Arjan de Vriesundefined Offline
    Arjan de Vries
    I have a gold membership. Make all my routes in MRA.
    I have a zumo XT.
    Do you check the route in basecamp?
    I ask this because I think that the here map in MRA is not the same as the (Up to date) map in the Zumo.
    Am I right?
    Thanks,
    Arjan
    Drabslabundefined Steve Lynchundefined Hans van de Ven MR.MRAundefined 4 Replies Last reply
    • Arjan de Vriesundefined Arjan de Vries
      I have a zumo XT.
      Am I right?
      Thanks,
      Arjan
      Drabslabundefined Offline
      wrote on last edited by Drabslab
      @Arjan-de-Vries no, absolutely not. Mra routeplanner is much better than basecamp. πŸ€—
      I gave not heard any complaints about the mra here map being outdated. I assume that mra works over a cloud connection to here and therefore always has the most recent versiob.
      • Drabslabundefined Drabslab
        @Drabslab said in Use of basecamp:
        Which means the map in Basecamp/on the Zumo is more likely to be "outdated", even if it's the most recent one available.
        So it could make sense to check if there are no differences with the map in Basecamp. However, you'll encounter "issues" even if the map matches 100%, for example due to temporary closures/road works/etc. I just tend to deal with those as I encounter them and I treat any differences due to map versions that are potentially still there in the same way as well.
          I have a zumo XT.
          Am I right?
          Thanks,
          Arjan
          Steve Lynchundefined Offline
          Steve Lynch
          @Arjan-de-Vries
          If you look at the very bottom of the right corner of the Here map you will see the following.
          Maybe someone from MRA can clarify?
            I have a zumo XT.
            Am I right?
            Thanks,
            Arjan
            @Arjan-de-Vries
            Hi Arjan,
            it's true that the map in Basecamp is slightly different from the most recent Here map used in MRA.
            I also have an XT and make all my routes in MRA, and I no longer use Basecamp.
              @Arjan-de-Vries
              @Steve-Lynch While I'm not sure why the copyright message doesn't seem to be up-to-date, I'm certain the maps are (pretty much) up-to-date, at least judging by some of the roads close to where I live that have changed in the last 6 months.
                Steve Lynch
                @Herko-ter-Horst
                My son lives in the vacinity of Fern Grove.
                Take a look at the differences between the Here and OSM Maps below.
                Here Map
                OSM
                • Herko ter Horstundefined Offline
                  What's your point? That maps from different suppliers differ?
                  BTW, this is the (c) 2022 map from https://wego.here.com/:
                  And this is the same area in the (c) 1992-2022 version of TomTom MyDrive:
                  If there's information missing, you can report it to HERE and TomTom directly using those websites. In my experience with TomTom, any changes I've reported have shown up within a few weeks in MRA as well.
                    @Herko-ter-Horst to my knowledge, and i dont know about the policies of garmin or mra, there is no guarantee that the basecamp map and the maps on zumo are identical.
                    For comparison sake only, microsoft tends to update some regions earlier than others.
                    Drabslabundefined Herko ter Horstundefined Con Hennekensundefined 3 Replies Last reply
                      In all honesty, i dont worry about this too much. Usually, roads are added, not removed and i guess that old roads continue to exist. Maps, whether on paper or digital, become outdated. This is most obvious with speed restrictions. Counting on your gps to avoid tickets is not a good approach. Routing and a nav app are tools, the most important part on the road is to keep your eyes open.
                        Could be. On my older device, I can use the exact maps from the device itself in Basecamp (with the device connected via USB), 100% guaranteed to be same.
                          I have a zumo XT.
                          Am I right?
                          Thanks,
                          Arjan
                          @Arjan-de-Vries
                          The roads can sometimes be drawn in a slightly different place.
                            To my knowledge, basecamp and zumo are updated from the same source. So if you update both, they should be exactly equal.
                            I think I have read on this forum before, that the Here mapsource (no not program!) for the planner and the Navigation app are not identical, and therefore small changes can exist due to differences in update schedules. It has not bothered me though. With clever use of waypoints the chance of noticeable difference is almost zero, and the ones I don't notice, well... I don't notice... πŸ˜‰
                              @Con-Hennekens said in Use of basecamp:
                              Yes they most likely are. But that do3sn't meab that they are updated at the same moment
                                Yes, but that renders it a user-error instead of a platform mis-design. Does Garmin Express not update both simultaneously (if you let it do that)?
                                Arjan de Vries
                                Drabslabundefined
                                Steve Lynch
                                • Route differences since new update!
                                  stuart marrittundefined
                                  stuart marritt
                                • Route als track hoe werkt dit nu?
                                  EMW-motorriddersundefined
                                  EMW-motorridders
                                  2.0k
                                • MRA useless after I missed a route turn
                                  paul69undefined
                                • What function does this icon perform?
                                • Silverfox C1 - routepunt overslaan
                                  Arjan de Vries
                                • Verlies van verbinding met het openbare internet met Android ( o.a Carpe Iter v4C )
                                  EMW-motorridders
                                • Bluetooth/Eternal Keyboard bug
                                • Just a black screen when startin myroute app
                                  Robert Laudensackundefined
                                  Robert Laudensack
