  3. My route is broken - Something went wrong while calculating the route
16 Posts 4 Posters 2.0k Views 1 Watching
  • Paul Slater 0undefined Offline
    Paul Slater 0
    "Something went wrong while calculating the route. Please make sure all waypoint are on roads and reachable using the selected transport mode and try again."
    Hi, I;'m away at the moment on a 6 day trip. I've had a route saved in My Routes but when I load it this evening it is now saying the above message. I need this route for tomorrow so I can Export it to my Satnav for a motorcycle journey to my next destination.
    Any ideas what I can do to make this work? I am a gold member if that helps.
    Many thanks
    • Paul Slater 0undefined Paul Slater 0
      Many thanks
      Jack van Tilburg
      @paul-slater-0
      I suspect you got the following message:
      Have you already clicked on the green field?
      There is a good chance that you will then receive a clue about the error that has arisen:
      There is a good chance that a waypoint has been placed in an inaccessible place. Check your waypoints to see if they are. be well positioned.
      Paul Slater 0undefined 1 Reply Last reply
        @paul-slater-0
        Paul Slater 0
        @jack-van-tilburg Hi, the error message doesn't offer the option to fix the route:
        Ive tried checking each waypoint to make sure it is centred exactly on a road but as soon as I try and adjust one I get the same error once more
          @paul-slater-0
          Hi Paul, please share tje url of your route here. Make sure it is set on Public
            @paul-slater-0
            Paul Slater 0
            wrote on last edited by Paul Slater 0
            @hans-van-de-ven-mra-master It is currently Private, how do I set it to Public please?
            OK I found out how 🙂
            Here is the route https://www.myrouteapp.com/route/open/5935324
              Paul Slater 0
              @paul-slater-0 I have been to each waypoint and zoomed right in to ensure each is centred on a road. But it still gave the same issue with each waypoint I moved a quarter of an inch.
              Now I have just added a new waypoint after (5) to aid the route, and it is now only calculating the route between points 21 and 22 as far as I can tell
              Hans van de Ven MR.MRAundefined Nick Carthewundefined 2 Replies Last reply
                @paul-slater-0
                No problem here:
                OSM Map:
                TomTom map:
                Here Map:
                  @paul-slater-0 When I FULLY zoom in some route points are off the road. If you look at route point 10 you will notice that you will get one of those annoying turns that immediately tell you to turn back.
                  912FF036-8CB8-46EE-A6AF-154FF5009ABE.png B915DBCF-8627-4178-8324-772D46EB7024.png 46F9755A-8CF4-4B26-B533-366B6D47E485.png 360C0A61-0552-4387-9C7A-DBF8F67B6B79.png
                    @Paul-Slater-0
                    I haven't checked the waypoints, as @Nick-Carthew points out, I just opened the route in the different maps, and as you can see it's just being calculated.
                      @Paul-Slater-0
                      Paul Slater 0
                      I checked them using Google Maps, not OSM, but the problem I have now is that the roite is not calculating at all and only showing the connection between the final two points
                      Is there a way to "force" a recalc of the whole route from 1 to 22 ?
                      Paul Slater 0undefined Hans van de Ven MR.MRAundefined 2 Replies Last reply
                        Paul Slater 0
                        @paul-slater-0 also the waypoints are now unnamed
                          @paul-slater-0
                          Open the route in the OSM map, go to point 1, zoom in to the max and set the point on the right position on the road, then point 2 etc
                            @paul-slater-0
                            Paul Slater 0
                            @hans-van-de-ven-mra-master Hi, I lready did this. I was using the Google Maps overlay not OSM, but I zoomed in to the maximum on each point (all 22 of them) and made sure it was on a road. The problem seemed to be that even when I dragged the ones that were slightly misplaced, the program then recalcluated for 20 seconds each time, and each time produced the error message as originally posted, so I'm not certain that the adjustments have "stuck", particualrly as the points are still showing as off the road.
                            The thing is, the route was working fine until yesterday evening, all the points were connected and all the waypoints had names.
                            It's beginning to seem like I might need to replot the route from start to finish
                              Jack van Tilburg
                              @paul-slater-0
                              Same route point, different maps.
                              You have to organise your route points with the OSM map and without an other overlay.
                              Google Maps
                              Opem Source Map
                              Paul Slater 0undefined Jack van Tilburgundefined 2 Replies Last reply
                                @paul-slater-0
                                Google Maps
                                Opem Source Map
                                Paul Slater 0
                                @jack-van-tilburg ahh okay, I didn't realise that. Thanks for the tip!
                                  @paul-slater-0
                                  Google Maps
                                  Opem Source Map
                                  Jack van Tilburg
                                  @jack-van-tilburg said in My route is broken - Something went wrong while calculating the route:
                                  And of course the Here map if you use Garmin or MRA Nav
                                  And the TomTom map when using TomTom navigation.
                                  But the same always applies and that is that you should not use a different overlay.
                                  Jack van Tilburg
                                  Paul Slater 0
                                    pehaundefined
                                    peha
                                    Stephen l. Weberundefined
                                    Stephen l. Weber
                                  • Veekeersinfo en omleiden
                                  • Last Route selection inconsistant
                                    RetiredWingManundefined
                                  • Updated beta! 5.2.1 (486)
                                    Leike Lodiersundefined
