  3. Maps do not show or only partly
17 Posts 5 Posters 3.4k Views 2 Watching
  • TorqueRider TorqueRider
    @gerrit-van-kuilenburg
    The phenomenon also occurs with me. On the Mac and the Macbook. Safari and Firefox. Refrsh has no effect. Just like removing cash and cookies.
    I am the only user on this network and the speed is not lower than usual.
    Het verschijnsel doet zich bij mij ook voor. Op de Mac en de Macbook. Safari en Firefox. Refrsh heeft geen effect. Net zo min als verwijderen van cash en cookies.
    Ik ben de enige gebruiker op dit netwerk en de snelheid is niet lager dan anders.
    Ticket aangemaakt: #30910 Kaart opbouw bibliotheek
      Gerrit van Kuilenburg
      @jack-van-tilburg Yep, accurate with my situation. Macbook / MacBook Air both the same behaviour exactly as you describe.
      Is there a solution? Its quite annoying. It was not like that in the past.
        @jack-van-tilburg Yep, I can reproduce the same issue...
        • Gerrit van Kuilenburg Gerrit van Kuilenburg
          @gerrit-van-kuilenburg said in Maps do not show or only partly:
          not that I know
          If I get an update on my ticket I'll report it here.
          • Darryl Moss
            Darryl Moss
            Darryl Moss
            I am getting the same issue, I on the verge of purchasing the MRA Gold product. The issue is if it's like this then its not worth paying of the product.
            Will be interested if there is a fix.
            Thanks
            • Darryl Moss Darryl Moss
              Thanks
              @darryl-moss I'm experience this only in the route Library. I expect it will be solved... MRA gold is still a good product if you make your own routes and even export them to other devices.
              For example, Basecamp is not so intuitive as MRA!
              Darryl Moss 1 Reply Last reply
                Darryl Moss
                Darryl Moss
                Darryl Moss
                @rob-verhoeff Hi Thanks for the quick reply, I agree MRA is easier than basecamp, will wait for it to be resolved before purchasing the product.
                Thanks
                • Darryl Moss
                  Darryl Moss
                  Darryl Moss
                  Looks like its working ok now...
                    Yep. It does indeed appear that the map is loading properly again.
                      @jack-van-tilburg toch benieuwd of daarmee jouw ticket ook wordt afgesloten en wat dan de onderliggende oorzaak was!
                        @rob-verhoeff
                        Ik denk niet dat de onderliggend oorzaak aan ons bekend gemaakt wordt.
                        In mijn ticket staat sinds gisteren:
                        "Ik zal het doorgeven aan de desbetreffende persoon zodra deze van verlof is."
                        Mijn interpretatie daarvan is dat er binnen MRA nog niets gedaan is. Waarschijnlijk lag de oorzaak buiten MRA (invloeden).
                        I don't think the underlying cause is being disclosed to us.
                        Since yesterday my ticket says:
                        "I will pass it on to the appropriate person as soon as they are off leave."
                        My interpretation of this is that nothing has been done within MRA yet. The cause was probably outside of MRA (influences).
                          @rob-verhoeff
                          @jack-van-tilburg
                          Ticket has been closed by MRA Support with the following notification via email:
                          "Glad to hear that the card is working properly again. Our programmer immediately started looking into the problem after his leave (It turned out to be a performance problem) and fixed it as soon as possible."
                          Ticket is door MRA Support afgesloten met onderstaande melding via mail:
                          "Fijn om te horen dat de kaart weer naar behoren werkt. Onze programmeur is na zijn verlof direct begonnen met het bekijken van het probleem (Het bleek een prestatie probleem te zijn) en heeft het zo snel mogelijk verholpen."
                            @jack-van-tilburg
                            @jack-van-tilburg bedankt voor het delen. Fijn dat het is opgelost.
                            Darryl Moss
                            Darryl Moss
                            • Newsletter optimisation
                            • How can I change colours in the route overview?
                              Kudee
                              Kudee
                            • Next: Ich brauche Hilfe zu POI und Favoriten!
                            • MRA AI Routeplanner - Improvement
                            • route aanklikken in overzichtskaart
                            • Walking route options
