  3. MRA Navigation APP
MRA Navigation APP
59 Posts 8 Posters 41.3k Views 3 Watching
  • Reinhard-32
    Reinhard-32
    Reinhard-32
    Or set the route to publish and share.
    Kindly regards
    Reinhard
    Montana 700i and Mac
    • HABVEN aka MrMRA
      The problem is that in Basecamp the road is not there.
        Reinhard-32
        Reinhard-32
        Reinhard-32
        #42
        @Hans-van-de-Ven-MRA-Master I can check it at my Win10 PC and my iMac pro but I have problems to find the exact location of the missing or not shown road in the map.
        Kindly regards
        Reinhard
        Kudee 1 Reply Last reply
        • Reinhard-32 Reinhard-32
          Kudee
          Kudee
          Kudee
          @Reinhard-32 https://www.myrouteapp.com/route/open/5364210/mobile#43.58887733921692;17.518429756164554;14///
          On MY Basecamp the Road ist ok 🙂
          • Reinhard-32
            Reinhard-32
            Reinhard-32
            #44
            Thanks for sharing the route. I have open the route in BaseCamp on both machines and found no differences. The gravel road is not there.
            Then I checked it at Here maps with the same result: The gravel road is not in the Here / Garmin map.
            When you switch off the track then you can see that the gravel road is not there.
            HERE Map:
            Map in BaseCamp on IMac with visible red track:
            Map in BaseCamp on Mac with invisible track:
            Kindly regards
            Reinhard
            • HABVEN aka MrMRA
              Same here
              • HABVEN aka MrMRA
                I think the conclusion is that Garmin provides different maps in different countries.
                Reinhard-32 Kudee 2 Replies Last reply
                  Reinhard-32
                  Reinhard-32
                  Reinhard-32
                  @Hans-van-de-Ven-MRA-Master No Hans, I don‘t think so. Here is the creator of the map and sells them to Garmin. Garmin prepared the map for using at garmin sat navs. When you look at the origin here map then yo can see that the discussed road is not there.
                  https://wego.here.com/?map=43.59131,17.52787,13,normal
                  Kindly regards
                  Reinhard
                    Kudee
                    Kudee
                    Kudee
                    Friends, I am embarrassed. This road doesn't exist in Basecamp and I didn't realize it. Shame on me. What I did is imported the track into Basecamp and converted it to a route. Looked at it in Bacecamp and it looks like a route.
                    Now I have loaded the route on my 595, the calculation works and the route can be started.
                    So again checked the Zümo, I do not have OSM maps installed.
                    I am now quite confused, thought I understand it after all these years.
                    Would Garmin now route me on the route even though it does NOT exist on the map?
                    Again, apologies and thanks to all.
                    lg Kudee
                    Translated with www.DeepL.com/Translator (free version)
                    • Nick Carthew
                      The road and route can be seen using the TomTom map in MRA. I thought TomTom was no good for off road 😊 e5c5cc58-45ff-4e51-9e91-c2aafb70de80-image.png
                        Kudee
                        Kudee
                        Kudee
                        @Nick-Carthew Nick, you miss out the point. Question is if Gamin would route me or not. MRA wouldn't. No problem with OSMand.
                        Hope i understand it the right way?
                        lg Kudee
                        • Kudee Kudee
                          lg Kudee
                          @Kudee I was being funny 😁
                            @Reinhard-32
                            In @Kudee basecamp NTU map the road is there I believe, but in my NTU map, same version, the road is not there
                            • Steve Lynch
                              Steve Lynch
                              Steve Lynch
                              #53
                              If it’s any consolation, Calimoto Premium uses OSM and it can’t route that particular track either. 😳
                              • Steve Lynch Steve Lynch
                                Kudee
                                Kudee
                                Kudee
                                @Steve-Lynch OSMand as well 🙄
                                  @Reinhard-32
                                  Reinhard-32
                                  Reinhard-32
                                  Reinhard-32
                                  #55
                                  Hans, see Kudee‘s comment here:
                                  What he saw was the track and not the road. In the Garmin map at BaseCamp the road unfortunately doesn‘t exist.
                                  Kindly regards
                                  Reinhard
                                    @Reinhard-32
                                    Thanks
                                    • Con Hennekens
                                      So...
                                      Happy that Here maps seem to be equal between MRA an Basecamp after all
                                      Unhappy that Here seems to be lagging after OSM.
                                      But perhaps Here considers this road as no road, while TT and OSM do. Is it drivable by car? I think for most map-makers that would be a factor of importance.
                                        So...
                                        Kudee
                                        Kudee
                                        Kudee
                                        Good question. Can the road be driven on by car? Or what are roads? I unfortunately do not have a track of the route driven in Ukraine (No Internet) also because the recording of tracks at MRA is poorly implemented. The track shown by me is legal to drive on. THAT should perhaps be the indicator whether the road / track is displayed.
                                        What about TET tracks? Are these visible in Garmin / MRA?
                                        lg Kudee
                                        PS: My 595 is still running and I have OSM loaded for each of the STAN states. My goal is to navigate only with the mobile.
                                        OSMand makes a good impression, 2 apps make it complicated again.
                                        • Kudee Kudee
                                          lg Kudee
                                          Steve Lynch
                                          Steve Lynch
                                          Steve Lynch
                                          @Kudee
                                          The TET routes are generally a mix of routable roads and off-road tracks.
                                          I.e. Linking off-road tracks together via routable roads.
                                          I have no experience with OSMand so can’t comment on that.
                                          The TET tracks are freely available so in theory you could import them into
                                          OSMand and see what you get.
                                          The Garmin XT can handle off-road tracks but the Here maps can’t as far as I know.
                                          Kudee
                                          Kudee
                                          Reinhard-32
                                          Reinhard-32
                                          Steve Lynch
                                          Steve Lynch
                                            martin-phogel.de
                                            martin-phogel.de
                                            12.0k
                                          • Issues on one-way streets when reversing routes
                                          • Route line is not easy to follow on map
                                          • F004 MRA Navigation Error
                                          • Probleem met eigen Stay
                                            Albert van den Elsen
                                          • Reclame van Navigation Next blokkeert de navigatie.
