  4. Replay Navigation Prompt?
7 Posts 5 Posters 3.5k Views 3 Watching
  • Ron Z
    Ron Z
    Ron Z
    Is there a option to replay the audio navigation prompt while a route is active? I'm not seeing it if it's available.
    2009 BMW K1300GT
    Garmin zümo XT
    Samsung Galaxy Tab Active 5 w/RAM mount
    2023 BMW R18 Transcontinental
    iPhone 14 Pro Max w/QuadLock mount
    Apple CarPlay in Carpuride W603D w/front-rear cameras
      Tap the current instruction window 🙂
      The most top left item om your screen.
      Ron Z Peter Zehentreiter Guzzist 3 Replies Last reply
        Ron Z
        Ron Z
        Ron Z
        @Corjan-Meijerink said in Replay Navigation Prompt?:
        Thanks. Tapping that worked once when I was at a standstill, but tapping again did nothing. I was trying to adjust my headset’s volume.
        2009 BMW K1300GT
        Garmin zümo XT
          @Corjan-Meijerink, @Ron-Z, I also have minor issues with this feature; sometimes it works, but sometimes it doesn't.
          Every other icon on the screen responds to even the lightest touch.
          But the one at the top left is very insensitive; sometimes you have to tap the icon several times and more firmly than the other icons.
          Can someone please double-check this?
          Tested on 2 different Android phones
          BMW R 1250 GS
          DMD-NOR7E 7"
          SPC Universal mount
          Motorola Edge 40 "offline"
          Sena SLR 3
          Sena 50 R
            @Corjan-Meijerink sorry, it seems it's not working on each device:
            • at my smartphone it's absolutely not working (ASUS ZenFone8, Android 13)
            • at my Navigation-Tablet it's working (DMD T865-X, Android 14)
            • at my Tablet it's absolutely not working (SAMSUNG Glaxy Tab S8 5G, Android 15, One-UI 7.0)
              @Peter-Zehentreiter said in Replay Navigation Prompt?:
              I don't think your phone screen is pressure sensitive 😉
              I think the thing is that there needs to be an instruction that can be repeated to begin with. If you start a route, and nothing is spoken yet, it cannot not repeat it. I never tested it, but I think the same happens when e.g. a waypoint note is spoken. After that, there probably is no instruction to be repeated. Maybe you can try and let us know.
                @Con-Hennekens I tested it while driving in the car...
                It is indeed as you say, that there are probably no instructions at the beginning of the route, which is why nothing can be heard when you tap on the icon.
                However, while driving, you can then produce the instructions, even repeatedly.
                BMW R 1250 GS
                DMD-NOR7E 7"
                SPC Universal mount
                Sena SLR 3
                Sena 50 R
                Ron Z
                Ron Z
                  Axel Lange
                  Axel Lange
                • In het kort......
                • Route probleem
                  Jack 13
                  Jack 13
