  4. Here Maps not Recognizing Road is now Open
26 Posts 9 Posters 9.3k Views 5 Watching
    @Adrian-Avram you can also edit & correct the Here map at https://mapcreator.here.com
    unlike OpenStreetMap where the edit is accepted almost immedialltey on trust, with Here each edit is reviewed before acceptance
    I find simple edits & changes with Here can take a few days to a couple of weeks OR they are not accepted
    if nothing has changed a year after your report then it has probably not been accepted
    Adrian Avramundefined Offline
    #21
    @Brian-McG said in Here Maps not Recognizing Road is now Open:
    As I said .... With HERE, I reported an issue more than one year ago, and nothing changed ...
    Nowadays you can check on Google Maps that a new street was built, if I add it to HERE, but nobody cares even to check and one years passes ?
    So I will stick to supporting and editing on OpenStreetMap !
    Adrian
      @Adrian-Avram said in Here Maps not Recognizing Road is now Open:
      Totally fine, but not helpful for MRA Navigation.
      I have heard much quicker acceptance of feedback from HERE too, by the way.
        @Con-Hennekens well what can I say ... I tried, but its useless unless they will leave people to change the map and improve it. Here map is much limited than OSM map unfortunately ...
        Adrian
          @Adrian-Avram, I understand what you are saying, but MRA Navigation happens to use HERE maps, not OSM.
            @Con-Hennekens yes I know ... unfortunately 😬 😁
            Adrian
            • John S Parryundefined Offline
              @Brian-McG I now understand what you did. I missed where you actually changed the calculation map from HERE to OSM. I had in my head that you were simply changing to the OSM overlay on a HERE calculation map.
              So yes, that method works. 👍 Thanks.
              Reinhard-32undefined
              Reinhard-32
              Kirsten De Weerdundefined
              Kirsten De Weerd
              ErikMatthezingundefined
              ErikMatthezing
              Ron Zundefined
              Ron Z
              • Waze warnings...
                ATLastundefined
                ATLast
              • Back from vacation
              • Moving the map
                Dave J 0undefined
                Leike Lodiersundefined
              • Route stuurt mij terug naar start punt bij Android Carplay
                jhawijnandsundefined
                jhawijnands
              • Mac to Garmin Zumo XT* GPX Transfer
                Van Hammée Lucundefined
                Van Hammée Luc
              • Track log functionality - compared with BaseCamp
