  3. [App] Announcements
  4. New update! (4.4.1)
New update! (4.4.1)
31 Posts 12 Posters 4.5k Views 3 Watching
    @Corjan-Meijerink said in New update! (4.4.1):
    Sorry for the inconvenience you experienced!
    Don't worry about it !
    I just drove a 80km route with 2 stops, everything is working just fine !
    Resuming navigation every time without any issue, and most importantly no more lagging !!!
    Hope it also works for all the other users with this issue.
    Great job !
    ginoginoundefined Offline
    ginogino
    @Adrian-Avram said in New update! (4.4.1):
    On Android, it's the same as before for me: the request appears to resume browsing and it stays there for hours if you don't press a button:
    As before if recalculation has been disabled, there are no off-route warnings.
    Within about 300km yesterday I had a couple of software crashes and had to restart my smartphone, something I had no longer had with the previous app, where can I find the previous app to download.
      Adrian Avramundefined Offline
      I would suggest trying to remove the app and reinstall it first !
      Adrian
      Samsung S24 Ultra and iPhone 13 with Android Auto / CarPlay
      • Justin Moremanundefined Offline
        Justin Moreman
        Can I ask how you update the app. I have looked through but cannot find a software update button?
          @Adrian-Avram, indeed. But clearing cache and storage (on Android anyways) usually leads to the same result.
          @Justin-Moreman, the app store of your phone handles that.
            #25
            Hey, just for your information,
            The iPhone XR's battery consumption throughout the day with three apps is perfect, including breaks where the apps weren't turned off.
            Charging was done with inductive charging in the cradle...
            Info zum Beta Test "Next App" dazu die Hardware ...
            iPad 9. Generation iOS 26.10.1 / Handy iPhone Xr iOS 18.7.1 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
              Hi everyone! 👋
              It has been 2 months since the last update. Now that the season is ending it's a nice moment to release a minor update. We are very happy with how the app (and the MyRoute-app platform in general) was a part of a lot of your adventures.
              This update will be available in coming days.
              Language updates
              Thanks to @Chudy and @Krzysztofa our app now supports the Polish language! 🎉 This is only the app, not the website. So if your app is in Polish, the website will probably be English (or whatever you selected).
              Android language select
              Since day one you could already select a different app language in iOS when accessing the iOS app settings. Now that's possible for Android too! 😏 Especially useful now we have Polish translations.
              Note: only Android 13 and higher
              iOS GPX import issue
              Since an update from iOS the GPX import function of the app was broken 😞
              That's fixed again! You can now open any GPX file sent to you with our app again.
              Recalculation improvements
              Tweaking the recalculation behavior of the app is quite complex due to the vast variety of situations. Over the holiday season we received quite some reports that the app would excessively skip waypoints. In this version we deployed a new version of the waypoint skip algorithm.
              Besides that we resolved an issue where sometimes recalculations in track navigation could get stuck.
              What's next?
              We are working on a major overhaul of the UI / UX of the app. We hope to start beta testing early September and aim for release in October! 🎉
              Cheers,
              Corjan
              @Corjan-Meijerink Hello Corjan,
              we want to go on another tour in Spain at the beginning of November.
              I would be interested to know whether the new update, which is due to be released in about two weeks, will fix the problem with the Silverfox C1 controller?
              (The controller only works when the app is set to English.)
              I would appreciate your answer.
              Best regards
              Peter
              BMW R 1250 GS
              BMW Connected Ride Cradle
              Wunderlich USB Ladebox mit Quadlock
              Pixel 9 "online"
              SPC Universal mount
              Motorola Edge 40 "offline"
              Sena SLR 3
              Sena 50 R
                Best regards
                Peter
                @Peter-Zehentreiter I don’t expect it to.
                In all honesty my perspective of this issue is that it’s Silverfox firmware related. Or at least, the fix needs to originate from them.
                We don’t do anything language based regarding these commands. We just receive keyboard commands and apparently in other languages the firmware from SilverFox sends incorrect ones?
                Absolutely not pointing fingers but I would not even know where to start in solving the issue.
                When using English language setting our app works correctly (as you indicated) because then (apparently) all correct keycodes are sent by the SilverFox firmware.
                  @Corjan-Meijerink First of all, thank you for your reply.
                  You're the professional, I'm the layman, so I should believe what you write...
                  Nevertheless, I find it hard to imagine that the fault lies solely with Silverfox.
                  The controller worked perfectly at first, but after about two months, the fault suddenly occurred, without any changes being made to the controller but changes were made to the App!
                  At the beginning of your post, you wrote the following:https://forum.myrouteapp.com/topic/9882/new-update-4.4.1
                  Since day one, you could already select a different app language in iOS when accessing the iOS app settings. Now that's possible for Android too! 😏 Especially useful now that we have Polish translations.
                  As a layman, I understand this as follows:
                  The Android app now also has the option to set the language, which was not possible before, but this feature is only available on Android 13 and higher.
                  I already mentioned in an email to you that I also have an old Android 12 device and the C1 controller works perfectly on it in German. (There is no option to change the language in the App)
                  As already mentioned, I'm just the user, but for someone who thinks logically, there must be a connection here.
                  If the error were exclusive to Silverfox, then the C1 controller should not work at all with the MRA App in German.
                  How can you explain, that the controller with the identical app version works on Android 12 but not on Android 14/15/16?
                  I´m curios to read your answer.
                  BMW R 1250 GS
                  Pixel 9 "online"
                  SPC Universal mount
                  Sena SLR 3
                  Sena 50 R
                    @Peter-Zehentreiter, check this website, on your phone, connected with your Silverfox, to see if it sends different keys when set for German or English.
                    https://jaxeadv.com/barbuttons/keypress-tester/
                    I find that hard to believe too, unless yo are using some key-mapping app on your phone that interferes with what the Silverfox sends.
                      @Con-Hennekens Hello Con,
                      thank you very much for trying to help here.
                      I have already read out the commands several times and also sent them to Corjan months ago.
                      ‘I had already opened a ticket.’
                      We even started an email conversation between me, Corjan and Riku from Silverfox.
                      Here's the story in brief again.
                      I bought the controller, installed it, and everything worked fine.
                      After about two months, I suddenly encountered an error that prevented me from zooming out.
                      I contacted Silverfox and described the problem. Silverfox sent me new firmware, but even with this new firmware, zooming out still didn't work.
                      Silverfox then sent me a completely new controller (tested by Silverfox on site in Finland and confirmed that all functions are working properly).
                      Even with this new controller, the error remained.
                      Riku then sent me an email suggesting that I should try to set the app to English, and immediately the zoom function worked again.
                      Until then, I still believed that the error could be with Silverfox, as Corjan was more or less certain that the error was not with MRA.
                      By chance, I connected an old device (Android 12) to the controller and it worked immediately, so I became suspicious and figured out that the update add language settings to Android could cause the error.
                      But you asked me to read the commands, what I did.
                      Attached is the link to the cloud containing images and videos.
                      https://1drv.ms/f/c/94b7ec629bb8bee5/Evg3NOH6GgxHgGzhKrIX--4BGjqKSEcw7-wov_2viLBNYw?e=NC2aKL
                      BMW R 1250 GS
                      Pixel 9 "online"
                      SPC Universal mount
                      Sena SLR 3
                      Sena 50 R
                        #31
                        Very briefly, I just have to add this here: a bug with Remotek One and the MRA up to MRA V3.x suddenly disappeared with the update to MRA V4.0.x. The Remotek One still has its old H&S version.
                        For a long time, I had a problem where, on an iPhone Xr with the keyboard control set to On, the MRA V3.x would crash outside of the navigation. So I always had to set it to Off, which unfortunately made some Remotek One functions unavailable. With the MRA update to MRA V4.0, I can now use everything because, with the iPhone keyboard control set to On, it no longer crashes. I'm happy with it, thanks for that!
                        Info Klick
                        From this, I conclude it was ultimately a button that was incorrectly positioned in the MRA... or rather, there were iOS updates at the time... as far as I know, it wasn't Remotek One's fault (Dag Jenssen).
                        Maybe it's just a matter of time until it resolves itself, like in my case! I'm glad it's resolved and hope it stays that way, because it was a real pain in the ass.
                        Thanks to everyone.
                        Ganz kurz, das muss ich einfach mal hier ergänzen, ein Fehler bei Remotek One und der MRA bis MRA V3.x mit dem Update auf MRA V4.0.x war er plötzlich verschwunden. Die Remotek One hat immer noch ihre alte H&S Version.
                        Lange hatte ich das Problem das bei einem iPhone Xr und dort bei eingestellter Tastatursteuerung =Ein der MRA V3.x außerhalb der Navigation abstürzte, desshalb musste ich diese immer auf = AUS stellen, damit waren einige Romotek One Funktionen leider nicht möglich. Mit dem MRA Update auf MRA V4.0 kann ich jetzt auch alles nutzen da bei der iPhone Tastatursteuerung = Ein jetzt kein Absturz mehr erfolg, ich bin glücklich damit, danke dafür !!
                        Info Klick
                        Daraus schließe ich es war letztentlich auch ein Knopf der in der MRA falsch stand .... bzw. in der Zeit gab es auch iOS Updats ... das was ich weiß, es lag nicht an Remotek One (Dag Jenssen).
                        Fielleicht liegt es ja zwischen den Stühlen bis es sich von selbst erledigt wie in meinem Fall ! Ich bin froh das das erledigt ist und hoffe das das auch so bleibt, den das hat mir auch Nerven gekostet.
                        Vielen Dank an alle.
                        RetiredWingManundefined
                        JP dundefined
                        JP d
                        Thomas Neumeyerundefined
                        Thomas Neumeyer
                        ginoginoundefined
                        ginogino
                        Justin Moreman
                        Manzo91undefined
                        Manzo91
                        Bert 2vundefined
                        Bert 2v
                        • MRA 5.0 - 422 RX Bibliothek - Download? - better to use the routes section on your phone? // Dowenload ? - besser unter Routen auf dem Handy ?
                        • MRA 5.0 - 422 Route / RoutesTrack Stop No / Navigate
                        • Option to Route through Closed Roads
                          John S Parryundefined
                        • 5.0.0 (422) Missing Map Details - CarPlay
                          Dave J 0undefined
                        • Het zou handig zijn als je ook je contacten zou kunnen gebruiken om daar naartoe te navigeren.
                        • Route Here Map
                        • V5.0.0.(422) - Waypoint List Icons
                          undefined
                        • Remotek-One Exchange of experiences
                          5.5k
