  3. XPert Routes_Way Points Clarifications
7 Posts 5 Posters 2.4k Views 3 Watching
  • Didos_2 Wheels Move the Soul
    Hi Team,
    hope you are all good and enjoying good rides.
    I am almost new to MRA Gold and trying to use the Xpert Library for "Route de Cretes Vosges_XXL".
    I downloaded it as GPX 1.2. On the Navigatin (I am not a member), it shows the routes and details of stops and what the route consists of (cafes, petrol, names of places) but when I am trying to open it from the Planner to see the details, it only shows "way points numbers".
    I apprecaite advising:
    1- How to see/convert from the navigation to the planner without looking and trying to open it directly from the planner ( i couldnot/took a lot of time searcning the internet with the route name and asked to open it n planner).
    2- How to see the details on the planner and what format to save it so i can see the all the details and be able to change and not seeing only the waypoints numbers without any details.
    I am attaching a screen shot to elaborate.
    Thank you,
    Best Regards,
    Ibrahim
    • Stanisław
      Why don't you simply use this button instead of downloading the route?
      Regards
      Staszek
        @Didos_2-Wheels-Move-the-Soul
        Without license okay, the transfer from the MRA planner to an external navigation system does not transfer the internal MRA symbols and functions additional texts etc., only the pure waypoints are transferred.
        Only internally means the MRA Navi app can use this 100%.
        Ohne Lizenz okay, das Übertragen aus dem MRA Planer an ein externes Navi überträgt nicht die internen MRA Symbole und Funktionen zusätzlichen Texte usw. , nur die reinen Wegepunkte werden übertragen.
        Nur intern heißt die MRA Navi App kann dieses zu 100% nutzen.
        VG 👋
        • Stanisław Stanisław
          @Stanisław said in XPert Routes_Way Points Clarifications:
          @Stanisław
          Yes, that is exactly the right way to transfer a route to your own route laboratory level so that everything is preserved ...
          Ja genau das ist der richtige Weg um eine Route in die eigene Routenlabor Ebene zu überführen so bleibt alles erhalten …
          • RainerT
            RainerT
            RainerT
            Yes, this also works with a free account.
            However, this only includes the openStreetMap route engine, and it is possible that a route may look different for you than it does for RouteXpert.
            However, with so many shaping points, the “risk” is low.
            Genau, das funktioniert auch mit kostenlosem Konto.
            Allerdings enthält das lediglich die openStreetMap Routenengine, und da ist es möglich, dass eine Route bei dir anders aussieht als beim RouteXpert.
            Die 'Gefahr' ist bei so vielen shaping points aber gering.
            • RainerT RainerT
              @Rainer-Treichel said in XPert Routes_Way Points Clarifications:
              Not correct. Wherever possible, RouteXpert routes are made equal for all planning maps by using the Compare route with tool.
                Hi All,
                Thnx all for the feedback. As I am new to MRA and the forum, I was waiting for the admin to approve the post :0). Then, I found all of your responses :0)).
                Sorry for that.
                If I use it as you suggested, "Use this Route", which format it will be. Will be able to see it on Zumo XT as is or modified through the phone.
                Thank you again.
                Ibrahim
                RainerT
                RainerT
                • Routenplaner on iPad
                • Rondrit generator ervaring
                  Sam Kramer
                  Sam Kramer
