  4. Show RX routes
Show RX routes
3 Posts 2 Posters 974 Views 2 Watching
  • Alessandro Calvani 0
    when "show RX routes" is active you could have a tooltip that positioned above the track shows the name of the route itself, otherwise it is impossible to understand which route it is even to search for it and display it
    • Alessandro Calvani 0 Alessandro Calvani 0
      @Alessandro-Calvani-0 The idea of showing MRA RX and MRA Scenic is to highlight the roads that are used, it acts in a similar way as the green roads on the Michelin map.
      If you want more information about the RX routes, use the RX library.
        OK, the library, but like in this case, there are two routes found in the library, but in reality there are many other routes in the area. Especially if you're looking at areas you're unfamiliar with, it becomes difficult to even find them. How do I find them? Wouldn't it be helpful to have a tooltip that gives me the name when I hover over the track (like it does when I click on the number because there are multiple routes in the area)?
          Rory Burke
          Rory Burke
