  3. Other travellers using MRA not following the defined route
9 Posts 8 Posters 2.5k Views 4 Watching
  • Roger Needham 0 Offline
    Roger Needham 0
    I am a Lifetime Gold Routeplanner. I therefore understand that the routes that i plan will be in HERE format.
    Some friends that are standard MRA Navigation users have noted that when we are out on the road, their 'version' will sometimes take them off the route that I am following. Is this because they will be using OpenStreetMap format?
    I have made sure that their settings are the same - (i.e. avoid tolls roads, no dirt roads)
    Are there any other tips and tricks to ensure folks all follow the same planned route?
    Thanks
    Nick Carthew nomko Adrian Avram 3 Replies Last reply
    • Roger Needham 0 Roger Needham 0
      Thanks
      Nick Carthew Offline
      @Roger-Needham-0 Everyone with an MRA Navigation Next subscription will have access to the planning map from HERE.
      • AWDC LAO Offline
        AWDC LAO Offline
        Everyone should take a GOLD membership.
          Thanks
          nomko Offline
          nomko Offline
          wrote on last edited by nomko
          Why everybody is recommending a subscription is not clear to me.
          @Roger-Needham-0 said in Other travellers using MRA not following the defined route:
          No, you can still use TomTOm and OSM as standard layer. This can be set in the pulldown menu were you choose your standard layer. Only with Gold you have TomTom and HERE. The default layer is OSM.
          No has basically not much to do with the layer (map). In some cases there arfe small differences between OSM, TomTom and HERE but this has more to do with how accurate and up-to-date the mapmakers maintain and update their maps. Nothing to do with MRA.
          Also, the choice of layer (map) to use will have not much influence in the route and how you drive it. My best guess is, is that your friends have reroute calculation switched on. And then you could run into the possibility that were you rturn right, your friends (or some of them) must turn left according to their navigation to get to the next waypoint (shorter route/shorter distance). You should check this.
          As said above, did you checked that they have reroute calculation turned off?
          Make sure if you share a route, you use the 1.1 format and not the 1.2 format for the GPX files. I noticed some small issues with the 1.2 format.
          Also, share it as a track, not as a route. There's a big difference between routes and tracks.
          Were routes use preplotted waypoints, tracks are made of hundreds point following your route which makes a tracj more accurate.
          | MRA Gold Member |
          | MRA Next + Kawasaki Z650 |
            Roger Needham 0
            Thanks Nomko, I will certainly get fellow travellers to check their ‘reroute calculation’ settings.
            I don’t tend to ‘share’ the routes I have created. I create a link to the folder in which I have stored the routes and then let my friends download the routes as they please. So some will just ‘use’ the routes if they are also MRA Navigation users, others will download to suit their device, eg TomTom, Garmin etc. I’ll pass on your tip to download any route as a ‘track’ as well 👍👍
            Rob Veerman Rob Verhoeff 2 Replies Last reply
              Rob Veerman Online
              Rob Veerman Online
              wrote on last edited by Rob Veerman
              @Roger-Needham-0 The users of a TomTom-device use another map and they can't switch off automatic recalculation. If a road that is used in the route does not exist in the map of the TomTom, the TomTom will automatically take another road on its map (part of the software design). If you want to avoid this you should compare the routes in Toolkit and erase the differences by changing waypoints..
              • Makro Offline
                Makro Offline
                Makro
                It's probably a matter of how many waypoints your route has. The more waypoints, the less options for alternative routes.
                Best regards, Makro
                  Thanks
                  Adrian Avram Offline
                  What do you mean by standard users?
                  If they are using Navigation Next, they will follow the same map as you, and that is HERE map.
                  Adrian
                    Rob Verhoeff Offline
                    Other MRA Navigation Next users do not need to download the route. If they are friends in the app/RouteLab, and you made the route available for friends, they can navigate directly to the relevant folder and start the route immediately.
                    Roger Needham 0
                    Roger Needham 0
                    Makro
                    Makro
                      Sytze van der Laan
                      Sytze van der Laan
                      Bruno 7
                      Bruno 7
                    • Hi again...Please help
                      Kudee
                      Kudee
