  4. Motorcycle “back button” ends the route navigation
carplayback buttonhondaafrica twinend navigation
8 Posts 7 Posters 3.2k Views 4 Watching
  • Siem van Malm
    Siem van Malm
    Siem van Malm
    In my case, whenever I press the “back button” on my motorcycle using CarPlay (Honda Africa Twin), it ends the navigation. This is very annoying.
    Would it be possible that whenever I press “back”, it just goes to the CarPlay homescreen while keeping the navigation active?
    I only want it to end the route when I specifically choose that option. alt text
      Are you sure the navigation really stops?
      I can only talk for Android Auto. But in many area's it is similiar to Apple Carplay.
      I believe you the app on your Carplay screen disappears but in Android Auto MRA does not stop navigating. When I put MRA back on the screen again it is like nothing happened
      If you want to stop the route you need to stop it with the onscreen button.
      Other question?
      Your Africatwin has touchscreen. Does this work when riding?
      Siem van Malm 1 Reply Last reply
      • M. Schrijver M. Schrijver
        Other question?
        Siem van Malm
        Siem van Malm
        Siem van Malm
        @M.-Schrijver unfortunately on Apple CarPlay it does indeed end the navigation. That’s my issues, I hope they can change that behaviour.
        To answer your second question, yes my screen is also a touchscreen, but it doesn’t work while moving, only when stationary.
        • Siem van Malm Siem van Malm
          @Siem-van-Malm said in Motorcycle “back button” ends the route navigation:
          Ending an active navigation requires pressing a confirmation button. If you did not see that, it does not come from within the app. Therefore your problem might be your (built in) AA/CP device specific.
          • Léon Hassing
            Léon Hassing
            Léon Hassing
            I also see that in AA. When I accidentally use the wrong button (on my BMW Wonderweel) I get the pop-up cancel or proceed navigation. I could select proceed, but then the tracking is not active anymore. You can only enable the tracking again on your phone. I know that is another issue, but it is caused by accidentally using the back button.
            • Rob Kelley
              Rob Kelley
              Rob Kelley
              yea I find the same on Apple Car Play, frustrating, there's no prompt, it just ends the nav.
              GSA1250
              HD Street Glide
              XT500 x 2
              • silberfuchs67
                silberfuchs67
                silberfuchs67
                I am using CP with the BMW WW and I am always asked to stop navigation or proceed via popup.
                  @Siem-van-Malm
                  1. Check your Input setting (in MRA setup) what is selected?
                  2. Check what your back button is sending to MRA (you can open an text editor and push the buttons to see what letter is sent)
                  Rob Kelley
                  Rob Kelley
                  Léon Hassing
                  Léon Hassing
                  silberfuchs67
                  silberfuchs67
                  Siem van Malm
                  Siem van Malm
                    Marcel Versluis
                    Marcel Versluis
                  • MRA Navigation Next: Synchronisation by folder
                    TomOnTour
                    TomOnTour
                  • Android Auto TFT
                  • Route punt overslaan
                  • Notche
                    Adriaan Vonk
                    Adriaan Vonk
