  4. Just hit 50 waypoints and it won't link to #51
5 Posts 4 Posters 1.3k Views 2 Watching
  • Chris Smith
    Chris Smith
    Chris Smith
    Not sure if it's an MRA limitation? Is there a limit on waypoints?
    Marinus van Deudekom Nick Carthew 2 Replies Last reply
    • Chris Smith Chris Smith
      @Chris-Smith yes there is
      Viapoints max 31 I believe and shaping points about 200
      -1
        @Marinus-van-Deudekom Incorrect information. MRA has a maximum of 200 route points, either shaping points or via points.
        Garmin has a maximum of 29 via points, if you use more than that the Garmin will create more than one route.
          @Chris-Smith There is a maximum of 200 route points. Are you seeing an onscreen message? I suspect that there is a problem with your route. If you could make it public and share it here in the forum, I’m sure that someone will be able to provide an answer and solution.
            Correct. MRA has no restriction apart from 200 waypoints (any type) total per route.
            Chris Smith
            Chris Smith
            • Startpunt wijzigen
              Ad V
              Ad V
              Ed van Klink
              Ed van Klink
            • Vrienden toevoegen
