  4. Navigating a track
Navigating a track
10 Posts 5 Posters 4.3k Views 3 Watching
  • C.A. Kielen
    C.A. Kielen
    C.A. Kielen
    wrote on last edited by C.A. Kielen
    I am going next week to countries where the Here map does not work properly a.o. Iran. I also want to drive some dirt roads in Armenia.
    It is clear that Here does not have good maps for Iran. I have planned the route with the OSM maps and OSM route calculations. Now I don't feel like using an other navigation app. I am used to the MRA app. My idea was to write out the route as a GPX 1.2 file and then start driving the track in the MRA app. Now I drove a GPX track with the MRA app last week, but really got the impression that the app doesn't follow the track, but rather keeps the roads (from the Here map) as close to the track as possible. So that's not going to work for me in Iran and offroad in other countries aswell. Am I doing something wrong, does a setting need to be changed? How do I make the MRA navigation app really follow the track and not nearby roads.
    Guzzist Rob Veerman 2 Replies Last reply
    • C.A. Kielen C.A. Kielen
      @C-A-Kielen may other high professionals will have better explanation. But let me try for an answer:
      At first: if you have planned a route at MRA-Rputeplanner, it's not necessary to export it as gpx file - and import it in MyRoute-App afterwards for navigation. In MyRoute-App, you can switch on auto sync of all. Then routes and tracks are on both, simultaneously!
      At second: if you open a synced route (or open an imported gpx file) you can select in MyRoute-App, to navigate this route as a track.
      BUT, to do the navigation, MyRoute-App is using always HERE map! Independent if you have planned this route in MRA-Routeplanner by another map. That's the issue you have seen.
      The point is: both - HERE map and MRA-Routplanner are not (yet) designed to operate offroad routes.
      My suggestion: do it as it is usually of offroad riding; plan it by OpenStreetMap, and open it in MyRoute-App on the bike, only to view it (don't start navigation). Then follow the line and compare by yourself, if you are riding still the same path in reality, as the line on the screen determines.
      Herman Veldhuizen C.A. Kielen 2 Replies Last reply
      • Guzzist Guzzist
        I also hope to see true track navigation at some point, when navigating as track. My scenario is a different one but has the same problem. I drive a bus and drive sometimes on roads which are closed for normal cars. HERE sends me around these roads, which is confusing especially when recalculation is disabled. Marking points as off-road/skip doesn't help.
        • Guzzist Guzzist
          C.A. Kielen
          C.A. Kielen
          C.A. Kielen
          @Guzzist said in Navigating a track:
          So yes, that is the problem, and if I understand you correctly, there is no solution for that within the MRA navigation have. I'm going to try your suggestion: Open the track, but not start navigating. Then follow the line on the screen myself. That won't make it any easier unfortunately.
          RetiredWingMan Guzzist 2 Replies Last reply
            @C-A-Kielen if you change the travel mode to by foot or by bicycle then you can open the route/track an then tap the compass to follow the route.
            C.A. Kielen 1 Reply Last reply
              @C-A-Kielen said in Navigating a track:
              try it - it only sounds more complicated as it is. It's most common for all offroad riders. You only need a little practice to get used to it.
              • Guzzist Guzzist
                C.A. Kielen
                C.A. Kielen
                C.A. Kielen
                @Guzzist Iast week I tryed a route and a track. It worked suprisingly good. Only you lost al your information from your waypoints.
                But this could be a good workaround.
                  C.A. Kielen
                  C.A. Kielen
                  C.A. Kielen
                  @RetiredWingMan that is an interesting option. For now: my bike and I are on the train to Turkey. For sure I will try this option there
                    @C-A-Kielen The app Maps.me is an excellent alternativ for trips like this. I have used it during motorcycle trips in Iran, Armenia and Georgia. Plan your trips in MRA in the OSM map and then export the GPX to the Maps.me app on your phone.
                    • Rob Veerman Rob Veerman
                      C.A. Kielen
                      C.A. Kielen
                      C.A. Kielen
                      @Rob-Veerman Ik heb het al jaren op de telefoon, maar nog ooit gebruikt. Ga ik ook zeker proberen. Dank voor de tip.
                      C.A. Kielen
                      C.A. Kielen
