  4. Preference travel
Preference travel
8 Posts 4 Posters 2.0k Views 3 Watching
  • Maurizio Malberti
    Maurizio Malberti
    Maurizio Malberti
    Good morning.
    How can I choose to travel on motorways?
    When I upload a.gpx file with highways to travel, the app lets me out and choose very long routes
    Thanks
    Marinus van Deudekom Herman Veldhuizen 2 Replies Last reply
    • Maurizio Malberti Maurizio Malberti
      Good morning.
      Thanks
      @Maurizio-Malberti maybe wou can share this route's url here and make shure it's set to public so we can help you
      • Maurizio Malberti
        Maurizio Malberti
        Maurizio Malberti
        https://www.myrouteapp.com/it/social/route/10915820?mode=share
        TomOnTour Marinus van Deudekom 2 Replies Last reply
          TomOnTour
          TomOnTour
          TomOnTour
          @Maurizio-Malberti Hi Maurizio,
          I just checken your route and if I look at all the shaping points in this route the route is absolute perfect. You have one section of motorways right after beginning and then another one on your way back. In between your shopping points are perfectly used by myRoute APP.
          Maurizio Malberti 1 Reply Last reply
          • TomOnTour TomOnTour
            Maurizio Malberti
            Maurizio Malberti
            Maurizio Malberti
            @TomOnTour yes, but when I use the app on my Samsung phone on android auto it always avoids highways. as if when using a common navigator, it was flagged avoid highways
              Good morning.
              Thanks
              @Maurizio-Malberti After you import a gpx file (with waypoints) you get to select route:fastest/shortest and highways yes/no in the Toolkit. When you navigate then the key is whether you navigate as track or not. When starting a navigation you only get to pick route:fastest/shortest and highways:yes/no when you navigate a route as route (and not as a track).
                @Maurizio-Malberti hi Maurizio
                I’ve looked at your route and I’ve noticed a couple of things.
                You use the TomTom map where MRA uses the Here map that allen can realy mess up your route.
                By the hotels in the long route I assume that it’s a 4 days trip. I would break that up in 4 trips. On a totall of more 1500 km there are only 52 waypoints in the route and a lot of them are OFF route. Look at nr 39 it’s on the wrong side of the road resulting in a massive detour.
                So Some tips
                Set the map to Here
                Cut the trip in 4 parts
                Use more shaping points
                Make sure they’re ON the route (zoom in max)
                Have fun
                  So Some tips
                  Set the map to Here
                  Have fun
                  Maurizio Malberti
                  Maurizio Malberti
                  Maurizio Malberti
                  @Marinus-van-Deudekom thank you very much
                  TomOnTour
                  TomOnTour
                  Maurizio Malberti
                  Maurizio Malberti
                  • Startpunt wijzigen
                    Ad V
                    Ad V
                    Ed van Klink
                    Ed van Klink
                  • Vrienden toevoegen
