  4. Route unexpectedly on toll roads
22 Posts 10 Posters 10.9k Views 4 Watching
  • Rajp
    Rajp
    Rajp
    Hi, I’m planning a route with avoid toll roads set, however MRA is still routing me onto the express way which is a toll road? Screenshot attached. Note: there are no way points or shaping points on the express way forcing that route.
    nomko Leike Lodiers 2 Replies Last reply
    • Rajp Rajp
      Banned
      @Rajp What's the route doing further down the route? Does it go back to your originall route?
      Can you post the link of that route so we can see whats going on? Make sure to set the route to public.
      Rajp 1 Reply Last reply
      • nomko nomko
        Rajp
        Rajp
        Rajp
        @Nomko-Nomden I've made it public: https://www.myrouteapp.com/en/social/route/10733492?mode=share
        • Rajp Rajp
          @Rajp Hi
          I've looked at your route
          I think I've found what's wrong.
          You chose the Bike profile and in that profiles some features don't work.
          I changed you route to car profile and there it was, didn't take the tollroad anymore
          Free tip
          You might want to add some extra shaping point to a route that long. More than 600km of 400 mls wiht only 13 shapingpoints is asking for trouble. Unless you don't mind the app calculating the route with those 13 point
          Have fun
          • Rajp
            Rajp
            Rajp
            That’s a bit disconcerting, is there a published list of features not supported by the bike profile?
            Stanisław Marinus van Deudekom MotoCon 3 Replies Last reply
            • Rajp Rajp
              @Rajp In general this avoid toll roads option does work with motorcycle profile, I have never had any problem with it. Maybe there is some problem with this info on the map.
              Regards
              Staszek
              • Rajp Rajp
                @Rajp that’s why I never use the bike profile. As far as I’M Concerned the little advantages of using the bike profile do not add up for the things that are not possible. That by the way is choice of Here not by MRA. So for ME it has little or no use and I’m staying with the car profile.
                As a RouteXpert for us it’s mandatory so everyone can use our routes
                • Rajp Rajp
                  @Rajp some extra shaping points on the expressway will help you with that problem.
                  • Tony 13
                    Tony 13
                    Tony 13
                    I thought once a route was created you could not change its profile?
                    I have a lot of "motorcycle" routes and would prefer to change dome of them to "car"
                    • Tony 13 Tony 13
                      @Tony-13 Open route and on the leftside select the hamburger menu
                      • Tony 13
                        Tony 13
                        Tony 13
                        that's easy 😊
                        • Rajp Rajp
                          @Rajp said in Route unexpectedly on toll roads:
                          Only thing is that there is no "shortest route" optimization for the motorbike profile. Can it be that the toll on that road is not applicable to motorbikes? or at least HERE THINKS it is? I cannot find that location in your route, so I cannot check. You could place a waypoint just before when this happens and tell us its number.
                          Rajp 2 Replies Last reply
                            Rajp
                            Rajp
                            Rajp
                            wrote on last edited by Rajp
                            @Con-Hennekens I've added shaping point 2, just after this you can see the route (black line) switching lanes to the express lane - and it's not free for motorcycles
                              Rajp
                              Rajp
                              Rajp
                              @Con-Hennekens Interestingly I created a copy of the route, and changed the navigation type to Car, and in that route it does NOT take me onto the express lane.
                              https://www.myrouteapp.com/en/social/route/10841161?mode=share
                              So perhaps Car is the best option to use for all route planning
                              • Rajp Rajp
                                @Rajp, I can't really find a clue. https://mapcreator.here.com/navlink:989811321/?l=32.9299,-117.1133,18,autoselect does not seem to reveal toll information. And the website about this road is seemingly blocked for foreigners wanting to plan a USA trip.
                                  Rajp
                                  Rajp
                                  Rajp
                                  @Con-Hennekens you probably have to pay import tariffs to view that site as a foreigner 😂
                                  • Rajp Rajp
                                    @Rajp, exactly my point 😉
                                      It is absolutely not true that the motorcycle is unstable as said by @Marinus-van-Deudekom.
                                      The only difference is that motorcycle has no shortest route option due to limitations at HERE. If a motorcycle takes a toll road where not expected (and allowed) this is just a mapping error which can be reported here: https://mapfeedback.here.com/#/report
                                        @Corjan-Meijerink Sorry Corjan
                                        I did not state that the bike profile is unstable.
                                        in this case the difference between the bike and car profile results in the routing by tollway. if you choose the car profile the route goes as wanted, in this case
                                          Just to make sure people aren't talking about different things:
                                          Are we talking about the 'bicycle' or the 'motorcycle' profile?
                                          Both could be referred to as 'bike', depending on where you're from.
                                          Marinus van Deudekom Peter Zehentreiter 2 Replies Last reply
                                          Rajp
                                          Rajp
                                          Tony 13
                                          Tony 13
                                          • Real-time traffic
                                            Andy Nicholson
                                            Andy Nicholson
                                          • HERE map not calibrated
                                          • Myrouteappstay
                                          • Navigatie met DMD tablet
                                          • Show on the maps's button
