  4. Route unexpectedly on toll roads
22 Posts 10 Posters 9.8k Views 4 Watching
  • Rajp
    Rajp
    Rajp
    That’s a bit disconcerting, is there a published list of features not supported by the bike profile?
    Stanisław Marinus van Deudekom Con Hennekens 3 Replies Last reply
    • Rajp Rajp
      @Rajp In general this avoid toll roads option does work with motorcycle profile, I have never had any problem with it. Maybe there is some problem with this info on the map.
      Staszek
      • Rajp Rajp
        @Rajp that’s why I never use the bike profile. As far as I’M Concerned the little advantages of using the bike profile do not add up for the things that are not possible. That by the way is choice of Here not by MRA. So for ME it has little or no use and I’m staying with the car profile.
        As a RouteXpert for us it’s mandatory so everyone can use our routes
        • Rajp Rajp
          Hi, I’m planning a route with avoid toll roads set, however MRA is still routing me onto the express way which is a toll road? Screenshot attached. Note: there are no way points or shaping points on the express way forcing that route.
          @Rajp some extra shaping points on the expressway will help you with that problem.
          • Tony 13
            Tony 13
            Tony 13
            I thought once a route was created you could not change its profile?
            I have a lot of "motorcycle" routes and would prefer to change dome of them to "car"
            • Tony 13 Tony 13
              @Tony-13 Open route and on the leftside select the hamburger menu
              • Tony 13
                Tony 13
                Tony 13
                that's easy 😊
                • Rajp Rajp
                  @Rajp said in Route unexpectedly on toll roads:
                  Only thing is that there is no "shortest route" optimization for the motorbike profile. Can it be that the toll on that road is not applicable to motorbikes? or at least HERE THINKS it is? I cannot find that location in your route, so I cannot check. You could place a waypoint just before when this happens and tell us its number.
                  Rajp 2 Replies Last reply
                    Rajp
                    Rajp
                    Rajp
                    wrote on last edited by Rajp
                    @Con-Hennekens I've added shaping point 2, just after this you can see the route (black line) switching lanes to the express lane - and it's not free for motorcycles
                      Rajp
                      Rajp
                      Rajp
                      @Con-Hennekens Interestingly I created a copy of the route, and changed the navigation type to Car, and in that route it does NOT take me onto the express lane.
                      https://www.myrouteapp.com/en/social/route/10841161?mode=share
                      So perhaps Car is the best option to use for all route planning
                      • Rajp Rajp
                        @Rajp, I can't really find a clue. https://mapcreator.here.com/navlink:989811321/?l=32.9299,-117.1133,18,autoselect does not seem to reveal toll information. And the website about this road is seemingly blocked for foreigners wanting to plan a USA trip.
                        Rajp 1 Reply Last reply
                          Rajp
                          Rajp
                          Rajp
                          @Con-Hennekens you probably have to pay import tariffs to view that site as a foreigner 😂
                          • Rajp Rajp
                            @Rajp, exactly my point 😉
                              It is absolutely not true that the motorcycle is unstable as said by @Marinus-van-Deudekom.
                              The only difference is that motorcycle has no shortest route option due to limitations at HERE. If a motorcycle takes a toll road where not expected (and allowed) this is just a mapping error which can be reported here: https://mapfeedback.here.com/#/report
                                @Corjan-Meijerink Sorry Corjan
                                I did not state that the bike profile is unstable.
                                in this case the difference between the bike and car profile results in the routing by tollway. if you choose the car profile the route goes as wanted, in this case
                                  Just to make sure people aren't talking about different things:
                                  Are we talking about the 'bicycle' or the 'motorcycle' profile?
                                  Both could be referred to as 'bike', depending on where you're from.
                                  Marinus van Deudekom Peter Zehentreiter 2 Replies Last reply
                                    @Herko-ter-Horst To be clear, the motorcycle profile 🙂
                                      @Herko-ter-Horst This discussion refers to the profile Motorcycle!
                                      BMW R 1250 GS
                                      DMD-NOR7E 7"
                                      SPC Universal mount
                                      Motorola Edge 40 "offline"
                                      Sena SLR 3
                                      Sena 50 R
                                      Tony 13
                                      Tony 13
                                      Rajp
                                      Rajp
                                        2.6k
                                        2.6k
                                      • Seizoensafsluitingen
                                        Arno van Lochem - Senior RX
                                      • Altitude numbers size
                                        2.4k
