  3. Odd MRA treatment of last shaping point
10 Posts 4 Posters 2.4k Views 3 Watching
  • twinfan
    twinfan
    twinfan
    Warning:  Lots of Garmin content.
    I recently began experimenting with MRA as a backup route planner while on trips.  Up to this point I have used Garmin BaseCamp exclusively and I am very comfortable with its operation.
    For practice I created a local route on MRA (Basic subscription) using only shaping points and sent it to the Zumo via the Garmin Drive app. Oddly, the Zumo preview showed the last shaping point as a flag as though it was a via point. As a check I saved the route as .gpx 1.1 in MRA, imported it into BaseCamp, and sent it to the Zumo via USB. Once imported by the Zumo, that same shaping point showed properly. Any thoughts as to what's different about MRA? See the screen captures below.
    Route in MRA (point 35 is the one in question):
    alt text
    MRA to Zumo, point 35 showing as via/flag:
    alt text
    Route in BaseCamp:
    alt text
    MRA to BaseCamp to Zumo, same point showing as expected shaping point:
    alt text
    Adrian Avram HABVEN aka MrMRA 2 Replies Last reply
    • twinfan twinfan
      alt text
      alt text
      Route in BaseCamp:
      alt text
      alt text
      @twinfan on MRA without a subscription, you are working with OSM maps ... Garmin is working with Here maps ! Maybe there is your issue.
      Adrian
      twinfan 1 Reply Last reply
      • twinfan twinfan
        alt text
        alt text
        Route in BaseCamp:
        alt text
        alt text
        @twinfan
        The dirst and last point are always via points (hard points as in BC) In BC all points are hard points.
        • Adrian Avram Adrian Avram
          twinfan
          twinfan
          twinfan
          @Adrian-Avram said in Odd MRA treatment of last shaping point:
          This area is well established and developed so hopefully the maps are close enough not to create an issue.
          @Hans-van-de-Ven-MR-MRA said in Odd MRA treatment of last shaping point:
          @twinfan
          I know there is some mixing of terms between MRA and BaseCamp. Shouldn't the second to last point (orange flag) then be a "soft" point (shaping point in BaseCamp terms)?
          Nick Carthew HABVEN aka MrMRA 2 Replies Last reply
          • twinfan twinfan
            @twinfan
            @twinfan said in Odd MRA treatment of last shaping point:
            It doesn’t matter how well an area is established or developed, each map has its own set of algorithms and it is these algorithms that dictate which roads are used and why you should use the correct planning map for your device. This is the point that @Adrian-Avram was highlighting.
            This will not be the cause of your problem, but I thought I would just mention it.
            • twinfan
              twinfan
              twinfan
              Thank you, @Nick-Carthew. I'm well established with BaseCamp but I can see the value in a Gold MRA subscription. I already found a routing problem with OSM while playing with MRA Basic. I would like the confidence of knowing the maps I use for routing are the same regardless of the planning tool.
              • twinfan twinfan
                @twinfan
                @twinfan
                Would you be so kind to share the url of the route, make sure it is set public
                • twinfan
                  twinfan
                  twinfan
                  Hopefully, I've done this correctly:
                  https://www.myrouteapp.com/route/open/10548910
                  • twinfan twinfan
                    @twinfan
                    Point 35 is correctly in the gpx file, as a shaping point, why the Zumo shows this as a flag, I dare not say.
                    Point 35 in the BC GPX file:
                    </rtept>
                    <rtept lat="38.721981095150113" lon="-121.224045753479">
                    <time>2025-02-13T07:38:26Z</time>
                    <name>4306 Old Auburn Rd, Granite Bay, CA 95746-6489, United States</name>
                    <sym>Flag, Blue</sym>
                    <extensions>
                    <trp:ShapingPoint />
                    gpxx:RoutePointExtension
                    gpxx:Subclass000000000000FFFFFFFFFFFFFFFFFFFFFFFFFF</gpxx:Subclass>
                    </gpxx:RoutePointExtension>
                    </extensions>
                    </rtept>
                    Point 35 in the MRA GPX file:
                    <rtept lat="38.721981115079" lon="-121.22404575348">
                    <extensions>trp:ShapingPoint/</extensions>
                    </rtept>
                    You can see that MRA uses fewer options than BC to compose the GPX file, but that can't be the reason that point 35 is shown as a flag in the Zumo.
                    I would create a support ticket via the website, so that the developers can look into this.
                    • twinfan
                      twinfan
                      twinfan
                      Thank you, @Hans-van-de-Ven-MR-MRA. I only have the Basic subscription for now so am unable to create a support ticket. However, I am also discussing this on the Zumo Users Forum. Many of the experienced Zumo users are also very familiar with MRA.
                      twinfan
                      twinfan
                      • screen
                      • Live tracking
                      • Rondrit generator ervaring
                        Sam Kramer
                        Sam Kramer
