  3. Map outline
Map outline
5 Posts 4 Posters 1.5k Views 2 Watching
  • Martin Proudlove
    Martin Proudlove
    Martin Proudlove
    I am going on a trip with mates in May (1800 miles/9 Days) and we are getting T-shirts printed. We want to have the outline of the route on the back with the over night stops on.
    Is there a way to shop the route with out the way points on?
    • Martin Proudlove Martin Proudlove
      Look up in Support: Manual 'Display and merge multiple routes'
      Martin Proudlove Con Hennekens 2 Replies Last reply
        Martin Proudlove
        Martin Proudlove
        Martin Proudlove
        @Nick-Carthew Thank you so much.
          @Nick-Carthew, this way you don't have the overnight stops on it.
          @Martin-Proudlove, Just thinking aloud: create a copy of your route. Make all waypoints shaping points except the overnight stays, keep them VIA points. In Navigation Next app enable "Navigate routes as tracks". Disable "All waypoints" waypoints. Then load the route in the Navigation Next and tap Navigate. In the next screen disable "Start from nearest waypoint" and also "Use current location". Swipe the option box as low as possible. Now you have the complete route, with only the VIA points visible in your screen. If you do this on a highres phone or tablet, I think the result will be good enough for a large print on a T-shirt.
            If you do it as Nick did, then you only need to add the POIs of the Hotels, B&B to make visible what you have driven per day. Every user will choose his own Hotel, B&B, Tent. In the example, the stops we made during the round trip on Skye. And you can also have these printed on a t-shirt
            Martin Proudlove
            Martin Proudlove
            • screen
            • Live tracking
            • Rondrit generator ervaring
              Sam Kramer
              Sam Kramer
