  4. switching map view (day/night) resets map style
nightdaymapdisplayswitch
5 Posts 2 Posters 2.1k Views 2 Watching
  • peha
    peha
    peha
    wrote on last edited by peha
    Whenever I switch between day and night display of the map (not the app theme!), the map's layout style which can be set via settings > navigation settings > map > map style > output (?! sorry, my app is German and I couldn't find a setting to switch in to English in order to give the right menu items; in German, the path is: Einstellungen > Navigationseinstellungen > Kartenebene > Kartenstil > Ausgabe) resets to "Explore (Standard)". Personally, I prefer to have the map display the "simplistic" style, but whenever I switch between day and night view, I have to set it to "simplistic" again manually. That's a little annoying - especially while driving with gloves on - and probably quite an easy fix. 😊 The problem occurs both when I switch between day/night view on the Android phone and via my Android Auto device.
    BMW F 450 GS: AA with Carpuride W702BS Pro (via Samsung S22 Ultra)
    • peha
      peha
      peha
      @Corjan-Meijerink I'm not sure if I should tag this topic in some way in order to prevent in from accidentally remaining unnoticed, so I'm mentioning you here. Please let me know how it's supposed to be done, is there's a better way. 🙂
        Thanks for informing me!
        I've fixed the issue where changing day / night from Android Auto (or CarPlay) would reset the theme to explore. This will be available in the next update automatically.
        I have not found an issue when exclusively using the phone.
        Switching day / night on the phone would not revert the style to explore. If this is the case, please provide the explicit steps you took.
        In my opinion I believe the issue was only present in the AA / CP settings button to switch between dark / night.
        peha 1 Reply Last reply
          peha
          peha
          peha
          @Corjan-Meijerink Thank you, it's great to hear that you have fixed it! I'm really looking forward to these new version, because that bug affects me surprisingly often, given that I switch a lot between vehicles and driving in sunlight, then at night and so on...
          I was wrong when I claimed it also happened when switching this at the phone directly, and I'm sorry if I have caused unnecessary debugging efforts: I can't reproduce it, myself, and must have misremembered.
          • peha peha
            @peha no worries 🙂
            Glad we got it resolved!
            peha
            peha
            • Real-time traffic
              Ã’scar
              Ã’scar
              Andy Nicholson
              Andy Nicholson
            • HERE map not calibrated
            • Myrouteappstay
            • Navigatie met DMD tablet
            • Show on the maps's button
