  4. Bulk Upload of POI's
25 Posts 8 Posters 7.6k Views 6 Watching
  • Mzokkundefined Mzokk
    @Dikke-Wim Somewhat less work than the method you describe👍
    Dikke Wimundefined Offline
    Dikke Wim
    @Mzokk
    What method do you mean? I don't get it.
    For me: the easier the better!
    • Dikke Wimundefined Dikke Wim
      @Martin-Wilcke
      Thanks Martin. It works now much better (see below).
      martin-phogel.de
      @Dikke-Wim
      • martin-phogel.deundefined martin-phogel.de
        @Dikke-Wim
        OK - I got it.
        You need an out centre (instead of an out geom) to create a single node for ways/areas. This will generate waypoints for both types (nodes and ways) when exporting as GPX.
        Here's the result
        https://hidrive.ionos.com/lnk/LhseBgcKc
        for the query:
        Sorry for the confusion!
        JP dundefined Offline
        JP d
        @Martin-Wilcke this is amazing never knew how to use this feature! It would be of great help if the MRA team @Corjan-Meijerink could make a YouTube tutorial on this. 🙏
        • BertMundefined BertM
          I do not think @Greenham want to harvest POI's but to put his own POI's into MRA in bulk.
          I use Excel to make them and then convert to GPX.
          MRA only uses the description but If I load them into my Garmin I get the other fields also. I am now busy to find out how to bulk import a GPX into my little housemade tool.
          Greenhamundefined Offline
          Greenham
          @BertM
          Yes this is what I am trying to do. Add my own POI's
          BertMundefined 1 Reply Last reply
          • Greenhamundefined Greenham
            @BertM
            BertMundefined Offline
            @Greenham said in Bulk Upload of POI's:
            @BertM
            As another member of this forum asked me the same because I replied here, I have been dusting off my 20 year old programming skills in Excel VBA 🙂
            the today status of the tools is the following
            • Import simple POI GPX files into Excel
            • Edit the imported file and add Symbol, Description, Street, Phone etc for import into Garmin devices
            • Export the POI file to GPX format
            • Double Click on the filled in row and the POI wil open in Google maps.
            Excel file with Ribbon (KML does not work yet)
            MOHO hotels GPX imported into Excel
            3rd Item in the list selected and button "Show in Google Maps" selected
            Import in MRA from GPX file
            Import in Basecamp with selected symbol
            Data added in Excel and transferred to Garmin GPX, see also the different symbols in the same GPX
            Send me your email in a PB and I send you the current file with the following status:
            • Made and only tested in Excel/Windows10
            • Error handeling is still poor in the progarmming
            • Program as is, it works on my system, not tested on other equipment.
            • Program is made in MS VBA and not tested in other programs.
            regards,
            Bert
            Adrian Avramundefined
            Mzokkundefined
            Dikke Wimundefined
            Dikke Wim
            JP dundefined
            JP d
            BertMundefined
            martin-phogel.de
            Greenhamundefined
            Greenham
              Jörgenundefined
            • New enlarge fuelstation icon gone to soon or not?
              Bouke Entundefined
            • No altitude on Android Auto screen
              Lluis Arasanzundefined
            • Altitude does not match
            • 5.1 update lost speed up in the corner
              7.6k
            • Adding a Via Point to or Edit a Round Trip
