  3. [Beta] Announcements
  4. Updated beta! 4.3.4 (372)
29 Posts 11 Posters 497 Views 6 Watching
  • Jörgen Offline
    Jörgen Offline
    Hi, I used the new version today for a 2-hour trip as A to B route on iOS CarPlay and everything went very well. Traffic jam and roadworks very announced and a shorter way during traffic was recommended. All were displayed on the car screen. The App is becoming better and better. 👍
    • Mopetenpit Offline
      Mopetenpit Offline
      Mopetenpit
      Hi, I would like to use Track Navigation:
      To do this, I take a route that I have created in advance in the MRA Webplanner. In the MRA Next settings, I set the “Navigate routes as tracks” switch to ON. Is that all or do I need to adjust other things?
      Peter
      • Mopetenpit Mopetenpit
        Peter
        @Mopetenpit, that's all indeed. You do have choice however to enable the visibility (ON) of all waypoints, or only the VIA points (OFF) on your track. The preferred method of track-navigation is still online. Of course only really relevant for the moments when recalculations occur (which you can disable now too).
        Mopetenpit 1 Reply Last reply
          Corjan Meijerink Offline
          @Jörgen Happy to read that you had a positive experience 🙂
          • Dave J 0 Dave J 0
            I planned a test ride with some of my favourite parts of mid wales in order to test version 4.3.4 - 272 properly on a long route with navigation of the route to be by track with only ‘vias’ showing - display of the navigation was through CarPlay.
            First issue was at the start as the app kept saying, “Reached Waypoint 40” (the end) and then ended the navigation! I had to ride the bike nearer towards Waypoint 1 and skip to Waypoint 2 for navigation of the track to resume correctly.
            All good and no problems on the way to Waypoint 7 for a disconnect and coffee break. On reconnect and recommencing navigation after the ‘stop’, I followed the app to see where it would take me and I followed the instructions to Waypoint 25 - the next via on what appeared to be the fastest route and not the desired track. The routetrack should have taken on a southern loop (white):
            Before stopping at Waypoint 25, I took a SE direction to backtrack the intended track to see what would happen. I was quickly presented with ‘recalculating’ as mobile signals for both data plans on my iPhone dropped but the app did not switch to ‘offline’ for the next 20 mins and the app appeared to have frozen when I stopped at Waypoint 25.
            The app had to be closed on the iPhone to resume the track recording but the app would not recalculate the route even though I had signal with both sims. A switch to offline also did not resolve the issue despite having the correct maps loaded for offline use. A soft reset of the iPhone did not resolve the problem either.
            Abandoning the route and setting a ‘course for home’ was met with repeated ‘no route found’ for offline and online. Manually selecting the destination from the map also did not help.
            Not sure what was happening but I will raise a support ticket with app logs attached for you @Corjan-Meijerink .
            Interesting trip.
            @Dave-J-0 Thanks so much for the elaborate feedback 🙂
            I've been working on fixing the mentioned issues and with joy can report the following changes that will be included in the next beta update / public release:
            • Fixed an issue with route not recalculating after deviating (when recalculations are enabled)
            • Improved determining the nearest marker to start route from (your route specifically had a specific case where the finish was closer than your start marker but the one before the finish marker was extremely far away. This caused your route to start at the finish).
            • Improve determining next waypoint when deviating from the route.
            • Improved route generator fallback option when not having internet / online route calculation failed (your last issue).
            Thanks again for the nice feedback. I believe all the encountered issues are resolved now in upcoming version 374 🎉
              Mopetenpit Offline
              Mopetenpit Offline
              Mopetenpit
              @Con-Hennekens Thank you very much for your explanations! Together with the new version (372) it now works as expected.
                Mopetenpit Offline
                Mopetenpit Offline
                Mopetenpit
                Of course I mean version 374!
                • paul69 Offline
                  paul69 Offline
                  This post is deleted!
                  • Jörgen Offline
                    Jörgen Offline
                    TestFlight says 375, Correct?
                    Mopetenpit
                    Mopetenpit
                      Peter Burch 1 0
                      Peter Burch 1 0
                    • How do I remove an old device?
                      Bruno 7
                      Bruno 7
                    • No location in Android Auto ! App unusable !
                      Jeff Causey
                      Jeff Causey
                    • Volume not restored after announcement
                    • Can others follow my progress using MY Route App?
                    • New update 5.2.1
                      1.8k
