  4. No voice prompts on Android phone
5 Posts 3 Posters 1.6k Views 3 Watching
  • Tony 13
    Tony 13
    Tony 13
    Hi, just been trying using Navigation in my car, on a Samsung phone. I am not getting any voice prompts, except for the very first turn prompt on one route I was following. Tried 4 different short routes.
    As far as I can see voice prompts are turned on and the volume turned up.
    App verson is 4.3.3. In Navigation settings everything seems to be on and voice prompts on in the route menu. I am not using Android Auto.
    Any suggestions? I will raise a ticket otherwise. Everything else seems to be fine with the navigation.
    • Tony 13 Tony 13
      @Tony-13 said in No voice prompts on Android phone:
      Hello,
      I would first check the Bluetooth (BT) connection with the cell phone:
      1. Turn off BT so that the announcement is made directly on the cell phone
      If that works:
      1. Pair the cell phone with the car media
      Good luck!
      Hallo,
      ich würde als erstes die Bluetooth (BT) Kopplung mit dem Handy prüfen:
      1. BT Ausschalten damit die Ansage am Handy direkterfolgt
      Wenn das klappt:
      1. Handy mit dem Auto - Media koppeln
      Viel Erfolg !
      iPad 9. G iOS 27.2.1/iPhone 16e iOS 27.2.1/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
      • Tony 13
        Tony 13
        Tony 13
        that's a good idea, thanks.
        I did, briefly, get a red bluetooth symbol appearing in the sound slider. Which i thought odd but, could not repeat it.
        • BMcG
          Hi @Tony-13 I suspect you are doing nothing wrong, you just need to know the secret codes !
          you may find useful info in these threads / posts by @Con-Hennekens & @Corjan-Meijerink
          https://forum.myrouteapp.com/topic/7504/text-to-speech-function-questions?_=1731096424400
          https://forum.myrouteapp.com/post/54260
          • Tony 13
            Tony 13
            Tony 13
            Thanks, useful information.
            On this occassion it was asimple route with no waypoints, I just wanted junctions announced.
            A, fortunetly, boring point. I have also been using Android Auto with no issues. Set up is on Ford SYNC3 and Samsung S20. Battery drain and heating of the phone are reasonable. Great work from the team
            Tony 13
            Tony 13
            • Heatmap menu: Display traveled routes
            • 'Geen adres bekend'
              PA. Vis 0
              PA. Vis 0
            • Feature request: support voor kaartview op kleinere schermen
              Ruud Bijkerk
              Ruud Bijkerk
              Johan 5q
              Johan 5q
            • Rondrit voert over een afgesloten weg
            • iPad - zooming out
              Big Al 1
              Big Al 1
