  4. TomTom Maps in navigation ?
24 Posts 10 Posters 9.5k Views 5 Watching
  • Adrian Avram Adrian Avram
    @Con-Hennekens MRA Navigation has only one map ! The Here map with different color schemes, and that is it unfortunately ...
    @Adrian-Avram said in TomTom Maps in navigation ?:
    Yes, how many maps does your TomTom or Zumo offer?
    You are using the wrong MRA planner map, for use with MRA Navigation, maybe that's clearer.
      @Hans-van-de-Ven-MR-MRA Problem has been addressed. Waiting for Here to update the maps accordingly.
      I think we can close this issue. Thank you for your support !
      Good find!
        @richard-3v nope, your route still takes me in the wrong direction, and then back to the waypoints. This is how my route is supposed to look like (plotted with TomTom map)
        The issue is with the map (Here map), i have reported the road section to be modified as highway on ramp and one-way lane.
        Here is the problem (Here as in the location :))))
        Hi @Adrian-Avram your post with this image clearly shows the issue
        alt text
        If you had done a little investigation by shortening the route like the image below, to just a couple of points where the route was going wrong, it might have been easier for people to understand from your first post where the problem was
        In future if you have issues with the Here map routing you can check for problems at https://mapcreator.here.com & actually edit/correct the map routing yourself. Whether Here accept the correction & how long it takes to go live is another issue.
        You can see below the map is corrected on Here, the update just needs to propagate to MRA
        • Brian McG Brian McG
          alt text
          @Brian-McG Yes its corrected now, because i have edited that road yesterday.
          Adrian
          TomOnTour
          TomOnTour
          richard 3v
          richard 3v
          • Rangen
            Pim van Dongen
            Pim van Dongen
          • Informatie Routeplanner Next
            OGRIII
            OGRIII
          • HELP! The Pyrenees Tour
            Pim van Dongen
            Pim van Dongen
          • Can not move WP
          • A19 Quick info about the WP incl. I miss the picture
