  4. Salvataggio Gpx 1.2
Salvataggio Gpx 1.2
5 Posts 4 Posters 1.2k Views 3 Watching
  • Vikings Bikers
    Vikings Bikers
    Vikings Bikers
    Salve, ho notato che salvando il File Gpx 1.2 e trasferendolo nel mio Garmin Zumo Xt2, ho notato che, il Garmin mi calcola una strada alternativa tra due Punti Waypoint, non seguendo esattamente la traccia creata.
    C'è un modo per evitare questo?
    Grazie
    • Mzokk
      I have an XT which may behave differently. But try putting more waypoints in when creating a route and export using GPX1.1. In the XT you are able to see the waypoints (MRA Naming as shaping points Garmin Naming) as little blue dots and if there are enough of them then the route will follow the intended path. Also make the track visible on the XT2 and you can determine where the deviations are.
      Vikings Bikers 1 Reply Last reply
      • Dave J 0
        @Vikings-Bikers As @Mzokk has said. Export as a GPX1.1 and import to the Tread App. You will then have route, track and POIs in a collection. That said, Tread App and the XT2 had a habit of modifying the route due to the sync from the Tread App. Not sure whether this has been resolved in the recent Tread App updates as I have shifted to using a Chigee AIO-5 Play CarPlay Display.
        Zumo User Forum for XT2 has some good information and this thread on the Tread App will inform a little more.
        Ducati Multistrada V4 Rally
        iPhone 18 Pro
        CHIGEE AIO-6 LTE
        Massimo Campanardi 1 Reply Last reply
        • Mzokk Mzokk
          Vikings Bikers
          Vikings Bikers
          Vikings Bikers
          @Mzokk Grazie
          • Dave J 0 Dave J 0
            Massimo Campanardi
            Massimo Campanardi
            Massimo Campanardi
            This post is deleted!
            Massimo Campanardi
            Massimo Campanardi
            Vikings Bikers
            Vikings Bikers
            • Real-time traffic
              Andy Nicholson
              Andy Nicholson
            • HERE map not calibrated
            • Myrouteappstay
            • Navigatie met DMD tablet
            • Show on the maps's button
