  4. Audible notification for via point
13 Posts 5 Posters 2.9k Views 2 Watching
  • Gordon Lawson
    Gordon Lawson
    Gordon Lawson
    Would it be possible to add an audible notification for when you are near/have reached a via point? I know there is information shown on the screen but if you're not looking at the screen you can go past your via point without noticing and miss it. Your route then goes on to the next via point without any notification. It doesn't necessarily need to be a spoken noticiation (although that would be good), even some kind of beep or alert sound would be fine.
    MotoCon Stephen Rowland 2 Replies Last reply
    • Gordon Lawson Gordon Lawson
      @Gordon-Lawson, The option is already in the audio settings:
      I choose "All" here, but only VIA is also possible.
      Gordon Lawson 1 Reply Last reply
        Gordon Lawson
        Gordon Lawson
        Gordon Lawson
        @Con-Hennekens Thank you - I had missed that!
        BMcG 1 Reply Last reply
          @Gordon-Lawson be aware that even though you select "All" mra may not always announce all points
          I am not sure of the cause / reason it does not always work but it has something to do with mra being busy calculating or making other announcements
          I wish this feature worked better, it's frustrating not knowing if a point will or will not be announced, it seems very random
          My tip would be not to put any point you wish to be announced anywhere near a junction & reduce the number of "voice prompts per instruction"
          I suspect the number of "voice prompts per instruction" are set at predetermined distances from junctions & if your point is within this zone, depending on your speed, there may or may not be time to announce the point
          • BMcG BMcG
            @Brian-McG, I think you are confused. As far as I know waypoint announcements are always okay. It is the route-instructions that are sometimes missed when waypoints are too close to junctions. Probably because the waypoint announcements take precedent.
              Stephen Rowland
              Stephen Rowland
              Stephen Rowland
              @Gordon-Lawson My solution to your problem works very well. Add a waypoint 500m before your via point and re-name it something like "Cafe coming up on the left". This will then be read out to you and you won't shoot past your via point. Do not write "Cafe coming up in 500 metres" because numbers won't be read out.
              • Stephen Rowland Stephen Rowland
                @Stephen-Rowland, shaping points are announced 750 before you reach them as it is, no need to place it 500mtr in advance. For Via points thats 2000 mtrs. I usually name the waypoint "Café WhateverTheName" and put "coming up at 500mtr. If you skip this one, the next one is in about half an hour." in the note field. This one get's read too, and numbers are no problem.
                BMcG Wil van der Helm 3 Replies Last reply
                  @Con-Hennekens  I think you are confused. As far as I know waypoint announcements are NOT always okay 😀
                  My experience is that shaping/via points may or may not be announced, the reason why some do or do not eludes me as I have been unable to observe a pattern.
                  I can guarantee you 1000% that point announcements are lost on both installs of MRA on my OnePlus 8T & Blackview 7100.
                  I normally run MRA with updated maps in offline mode with the phones set to flight mode & no other apps running to conserve battery.
                  Voice prompts are always enabled as I like to keep my head up & eyes on the road & use the announcements as a nudge to check the route on the app display.
                  Your post is the first time I have seen information about distances associated with when & where points will be announced.
                  My suspicion is that something like fixed trigger distances can result in a clash of demands within mra e.g. if I am at a junction 2001m before a via point & mra is busy giving me instructions about that junction, the via point announcement for 2000m ahead is lost.
                  MotoCon Wil van der Helm 2 Replies Last reply
                  • BMcG BMcG
                    @Brian-McG said in Audible notification for via point:
                    It's the other way around.
                      Wil van der Helm
                      Wil van der Helm
                      Wil van der Helm
                      This post is deleted!
                        Wil van der Helm
                        Wil van der Helm
                        Wil van der Helm
                        you say " I usually name the waypoint ". do you mean the shaping point or the viapoint ?
                        • BMcG BMcG
                          Wil van der Helm
                          Wil van der Helm
                          Wil van der Helm
                          @Brian-McG @Con-Hennekens
                          i thought the text-to-speach was read when passing the preceding (shape or via} waypoint, and has nothing to do with distances !?
                          • Wil van der Helm Wil van der Helm
                            @Wil-van-der-Helm said in Audible notification for via point:
                            Can be both. Both can be set to be announced independently.
                            That's incorrect. The announcement takes place 750mtrs for shapingpoints and 2000mtrs for viapoints. An exception is made if there is an upcoming waypoint preceding the one with the announcement. In that case the announcement is spoken when the preceding waypoint is passed. This way you are able to shorten the distance to the announcement.
                            Stephen Rowland
                            Stephen Rowland
                            Wil van der Helm
                            Wil van der Helm
                            Gordon Lawson
                            Gordon Lawson
