  4. Merging tracks/Converting tracks/Manual
trackmanualbasic
5 Posts 4 Posters 1.4k Views 2 Watching
  • Thomas Schäfer
    Thomas Schäfer
    Thomas Schäfer
    Hello forum,
    Since my questions might get lost in the “New Users Corner”, I'll take the liberty of asking them again here in a structured way or adding to them.
    My first problem concerns the merging of individual tracks into a complete track.
    I have now read in some posts that this is not possible but that you should first convert the partial track into a partial route and then combine these partial routes into a complete route.
    Apart from the fact that I don't need a route but the complete track, so that doesn't solve my problem, I unfortunately haven't yet found how to convert a track into a route.
    So my workaround would be to continue using Basecamp to summarize the individual tracks and then import them into MRA.
    Is there some kind of user manual that describes basic functions like this?
    I would like to read up on the basics before I have to ask about every little thing here.
    Thank you very much for your patience
    Thomas
    Freundliche Grüße/Kind regards/Met vriendelijke groeten
    Thomas
    • Thomas Schäfer Thomas Schäfer
      Hello forum,
      Thomas
      @Thomas-Schäfer said in Merging tracks/Converting tracks/Manual:
      Did you notice the support section?
      • Bacus
        Bacus
        Bacus
        I miss this simple feature too, workaround works, but If it is possible I don't want to use basecamp, no more.
        • Léon Hassing
          Léon Hassing
          Léon Hassing
          I always use JaVaWa GPS-tools for this (https://www.javawa.nl/rtwtool_en.html). You can also add heights to your track or convert it to several other file types.
          Or you can use Gotoes (https://gotoes.org/tools/merge-gps-files).
          • Thomas Schäfer
            Thomas Schäfer
            Thomas Schäfer
            Léon, thank you very much for pointing out Javawa. I’ve known about and used Javawa’s tools for years, but I hadn’t come across rtwtool before. It works perfectly!
            Thomas
            Thomas Schäfer
            Thomas Schäfer
            Léon Hassing
            Léon Hassing
            Bacus
            Bacus
              David 38
              David 38
            • Download club route folders
            • Passwords
              Captain Haddock
              Captain Haddock
              Ed Lauwerens 0
              Ed Lauwerens 0
