  4. Start Navigating Route Part-Way Through
3 Posts 2 Posters 962 Views 1 Watching
  • Graham Aitken
    Graham Aitken
    Graham Aitken
    WIth the Garmin Zumo XT, when starting a Trip (multi-waypoint route), it gives you the option of beginning at a particular waypoint, and lists all of the waypoints. This can be really helpful when riding a complicated route, if things just go completely wrong you can re-start the route at the next waypoint. Is there the ability to do this when navigating with the MRA app ?
    • Graham Aitken Graham Aitken
      @Graham-Aitken yes, there are several ways to do what you want. The easiest may be, after loading your route and hitting the Navigate button, the entire route is displayed. Simply long press on the waypoint you want to start navigating from, then hit the Start button.
      As an alternative, after hitting Start, you can long press the compass to bring up the entire route (or use the menu to display the route) zoom in on the map to locate the waypoint you wish to start navigating from and long press on the way point. Now tap the compass to be8ng navigating.
      You can also use the menu to display a list of waypoints. Simply long press on the waypoint you want to start at and return to navigation.
      Graham Aitken 1 Reply Last reply
        Graham Aitken
        Graham Aitken
        Graham Aitken
        @RetiredWingMan Perfect - many thanks ....
        Graham Aitken
        Graham Aitken
