  3. [App] Announcements
  4. Roundabout issue solved
21 Posts 11 Posters 13.3k Views 7 Watching
    The issue where in motor mode the displayed / announced exit number for a roundabout would always be “1” has been solved for the online maps by HERE 🙂
    Offline maps / other transport modes did not have this issue. The fix is independent of any app update 😉
    Bart De Medts Hubert Thoring M. Schrijver Jeremy Thomson 0 4 Replies Last reply
    • Brian Martin
      Brian Martin
      Brian Martin
      Information box still not working with v311
      • Brian Martin Brian Martin
        @Corjan-Meijerink : Super und Danke dafür 👍
          @Corjan-Meijerink 🎉 🎉 🎉
          • Rob Verhoeff Rob Verhoeff referenced this topic on
            @Corjan-Meijerink : klappt sehr gut jetzt 👍
              @Corjan-Meijerink said in Roundabout issue solved:
              Offline maps ..........
              Ahhh, this is why i didn't had the issue. I always use the Offline Maps
              Guido Schulte 1 Reply Last reply
              • M. Schrijver M. Schrijver
                Guido Schulte
                Guido Schulte
                Guido Schulte
                Gestern ausprobiert und alles wieder Gut, meinen besten Dank an Alle die das wieder in Ordnung gebracht haben.
                • No6671
                  No6671
                  No6671
                  Thanks for hard work.
                  Goran
                  Get up. Travel. Make friends. Sleep. Repeat.
                  • richtea999 richtea999 referenced this topic on
                  • Brian Martin
                    Brian Martin
                    Brian Martin
                    I still have a problem using in Android Auto. Most of the time the information box does not work and when it does it shows wrong information. Either the direction arrows show wrong way, the up and coming road still shows the first road of the journey and wrong road number. The information is correct on the phone but doesn't seem to make it onto the cars screen. So I have decided I've had enough and shall be using "Here WeGo" app which seems to use the same Here mapping system but it works perfectly in Android auto. Obviously the downside is I will be unable to download gpx files from the website, but as I tend to plan routes on the fly it shouldn't be too much of a hardship.
                      Jeremy Thomson 0
                      Jeremy Thomson 0
                      Jeremy Thomson 0
                      It does not seem to be fixed for me - every roundabout still says "take the first exit". It does it with both online and offline maps (iphone SE).
                      Do I need to delete and reload the maps?
                      TomOnTour 1 Reply Last reply
                      • Jeremy Thomson 0 Jeremy Thomson 0
                        TomOnTour
                        TomOnTour
                        TomOnTour
                        @Jeremy-Thomson-0
                        Hi Jeremy!
                        I had the same issue, but with a little help form my friends here and some personal investigations I found out the issue in detail:
                        When your re suing the online maps with online routes, than all is fine.If you are using „Donloaded Roues“ the APP thinks you work offline and so you still have this issue. Mihai the problem yesterday and just used today an online route, instead the downloaded version and all worked fine for me.
                        Thomas
                        MyRoute-APP Navigation Next (V5.2.2 - 489) on DMD T781
                        Jeremy Thomson 0 1 Reply Last reply
                          Currently I am in Scotland. But it is far from solved. I ride with Android Auto
                          The map is OK.
                          The spoken directions are OK as far as I've noticed.
                          But the big info box at the top left shows no roundabout at all. It shows only left or right. Where it is nearly always the wrong direction.
                          The little info right below it (lane assistance). Does not show always the right info either.
                          Jörgen 1 Reply Last reply
                            The map is OK.
                            @M-Schrijver hi, I don't know if this is a problem with left-hand traffic, but I've been driving the latest version for over a week now without any problems with roundabouts
                              I did not notice any strange things in The Netherlands. In England I did see roundabout signs/icons in the upper left box but I do not know if they were correct. I was to busy to adjust to riding on the left hand side of the road. But here in Scotland all roundabout signs/ icons are missing. Just left or right
                              • TomOnTour TomOnTour
                                @Jeremy-Thomson-0
                                Hi Jeremy!
                                Thomas
                                Jeremy Thomson 0
                                Jeremy Thomson 0
                                Jeremy Thomson 0
                                @TomOnTour Thanks Tom. I ended up reloading the offline maps and it fixed the problem.
                                  I use MRA offline but still not good.
                                    @M-Schrijver said in Roundabout issue solved:
                                    Try changing transport mode from motorcycle to car. I have just returned from Scotland and I had no issues at all.
                                      I will check it but I'm pretty sure my profile is "car".
                                      Just to be clear. It is what my Android Auto screen is showing. I don't know what is on my phone screen.
                                        TomOnTour
                                        TomOnTour
                                        TomOnTour
                                        Ok. Got it. Then I am out. I was only speaking about the iPhone APP with no CarPlay connected.
                                        Thomas
                                          Did some checks today
                                          100% sure it is in Car mode
                                          Phone shows it correct
                                          Android Auto make a mess of it
                                          TomOnTour
                                          TomOnTour
                                          Brian Martin
                                          Brian Martin
                                          No6671
                                          No6671
                                          Jeremy Thomson 0
                                          Jeremy Thomson 0
                                          Guido Schulte
                                          Guido Schulte
                                          • Missing info from CarPlay
                                          • File en omrijden
                                            Robineke
                                            Robineke
                                          • Geen pictogram van een motor
                                          • Routenplaner on iPad
                                            Risto Motorcycling
                                            Risto Motorcycling
