  3. [App] Announcements
  4. New update! (4.1.2)
New update! (4.1.2)
22 Posts 10 Posters 13.0k Views 6 Watching
  • dungbeetle dungbeetle
    Since the update I am experiencing routing errors.
    The three pictures below show how the routing differs between viewing the maps prior to setting off and the actual route the app takes when travelling.
    I can't seem to change the map when travelling as I assume that this is always the default. Is there a way to fix this problem by using different maps during planning, or could this be a bug? (I have been using the default 'HERE' maps to plan on PC, as recommended in the past.)
    As you can see in the pictures, the app wants to take me via a residential slip road rather than just staying on the main road.
    Thanks,
    d.
    JP d
    JP d
    JP d
    @dungbeetle I think this is due to the Here map as my Garmin which uses the Here map has done this twice.
      Hi everyone! 😃 👋
      Next week a new update will be available to you all! 🎉
      The following things have been changed.
      Tracklogs in groups / events
      You can now view tracklogs of not only yourself / friends but also for groups & events! 🎉
      The main reason to implement this is to also facilitate the Navigation specific events (yes, this might needs some renaming on the website 😉). When you've marked an event as such, the tracklogs recorded for those routes will be added to the event automatically 😏
      As this means the tracklog needs to be saved while the route is still open, you will see a slight change in the app regarding stopping your navigation. When you stop the navigation, the route will still be displayed in the main (home) screen.
      iOS crashes
      We've continued working on the stability of the app. This should have led to a dramatic decrease in random crashes you get on iOS when for example not actively using the app.
      Nearby fuel stations
      We've massively improved the search algorithm for fuel stations along your route. Get on the road with this version and do let us know what your experiences are! 🙂
      Besides providing you with better recommendations, the fuel station is also displayed on the map 🙂 That is also visible on your CarPlay / Android Auto display.
      Display of search results
      When searching for destinations along your route, we now display them on the map too! 💥 This gives a great overview of any search results relevant to you. If searching for fuel, we will quickly show all the possibilities along your route.
      Resume navigation from CarPlay / Android Auto
      When you've got the possibility to resume an active navigation session, CarPlay / Android Auto will ask you if you want to resume this in a more instinctive manner.
      Fix incorrect lane assist
      Lane assist icons were often incorrect due to a mistake from our side. That has now been corrected 😉
      Improved auto-skip algorithm
      The algorithm that determines what should happen when you seem to ignore waypoints has been changed. We got some feedback that is was too aggressive so that has been improved. Do remember, you can always disable the auto-skip feature completely and viapoints must always be skipped manually 🙂
      What is next?
      The 4.1.3 update will definitely include the possibility to select any of your routes from CarPlay / Android Auto. Besides that we will add some more stuff to those platforms and continue working on the stability.
      Best,
      Corjan
      JP d
      JP d
      JP d
      @Corjan-Meijerink any update on battery drain? Thank you for continued improvements I always eagerly await what you're going to improve or add next. 🍻
      • Stefan Hummelink Stefan Hummelink referenced this topic on
      Karel76
      Karel76
      JP d
      JP d
      GT JWR
      GT JWR
      dungbeetle
      dungbeetle
      Jannes van Dijken
      Jannes van Dijken
      • Missing info from CarPlay
      • Routenplaner on iPad
      • File en omrijden
        Robineke
        Robineke
