  3. Switzerland trip
Switzerland trip
13 Posts 6 Posters 3.7k Views 1 Watching
  • Andrew Vaughan
    Andrew Vaughan
    Andrew Vaughan
    Hello , sorry if I'm wrong forum first post ,
    I was seeing does anyone have some routes around the area I will be staying in Switzerland (Saint-Luc )? We are doing the 3 passes but this can be done in a day I believe . We will be there for 5 days. Any other good routes. I've had a look in the Library but they seem to be a few hours away just to join the route. Thank you.
    Nick Carthew MotoCon Kudee 3 Replies Last reply
    • Andrew Vaughan Andrew Vaughan
      @Andrew-Vaughan The great thing with MyRoute-app is you can take a route from the RouteXpert library, add it to your library and adjust it to suit your needs.
      • paul69
        hi @Andrew-Vaughan
        you could use the "create scenic route option" you would then have a rough idea of a route that suited your needs and adjust as necessary.
        i also agree with @Nick-Carthew it is quite easy to play with other routes and make them fit
        K1600 GTL
        iPhone 13 Pro, carpuride 702b
          @Andrew-Vaughan, Maybe you can find some inspiration here:
          https://www.myrouteapp.com/nl/info/collection/62
            Kudee
            Kudee
            Kudee
            @Andrew-Vaughan said in Switzerland trip:
            Saint-Luc
            I stay in Switzerland, can give you some tips. Where dou you start from?
            Andrew Vaughan 1 Reply Last reply
            • Kudee Kudee
              Saint-Luc
              Andrew Vaughan
              Andrew Vaughan
              Andrew Vaughan
              @Kudee
              Hi
              We are staying in Saint -Luc so that's our start point every day 👍🏻
              Kudee 1 Reply Last reply
                @Kudee
                Hi
                Kudee
                Kudee
                Kudee
                @Andrew-Vaughan
                Saint-Luc
                3961 Anniviers
                • Erdna
                  Erdna
                  Erdna
                  Hi Andrew,
                  Saint Luc is not the best option as "basecamp" in my opinion because of it´s location.
                  How many km would you like to ride each day? Just on road or with some off-road elements? What bike? Do you ride alone or with friends? Questions over questions... 🙂
                  For your consideration: a personal "POI list" with many passes, interesting places, etc.: https://www.google.com/maps/d/u/0/edit?mid=1wRIVqBxCOUcmLwVvuTIejBr5bh_r4pA&usp=sharing
                  Unfortunately, this cannot be done in MRA, because of too much entries.^^
                  Regards,
                  André
                  • Erdna Erdna
                    Hi Andrew,
                    Regards,
                    André
                    Andrew Vaughan
                    Andrew Vaughan
                    Andrew Vaughan
                    @Erdna Sadly its all booked for 4 of us is this not a good place ? where would be better ? there is no off road wanted all tarmac roads only . thank you
                    Andrew
                    • Erdna
                      Erdna
                      Erdna
                      @Andrew-Vaughan It´s no bad place, but every day you will have to get out of Val d’Anniviers and after the tour back into it.
                      That means: the nearest summit in eastern direction is the Simplon pass. It´ll cost you approx. 90 minutes to get there if you use the highway. And of course you´ll have to return the exact way for another 90 minutes to get to Saint Luc.
                      The nearest summit in western direction is Col de la croix de coeur, which is also approx. 90 minutes using the highway...
                      Worst: you don´t have options to go north / south from Saint Luc because every possible route will leave you in a dead end. You´ll simply have to do that 90 minutes east or west to get anywhere else. That´s three "lost" hours every day. 😞
                      Andrew Vaughan MotoCon 2 Replies Last reply
                      • Erdna Erdna
                        Andrew Vaughan
                        Andrew Vaughan
                        Andrew Vaughan
                        @Erdna thanks for the info 👍🏻
                        • Erdna Erdna
                          @Erdna, Yes, riding/planning in Alps/Dolomites is a lot more complex then let's say Eifel, Ardennes, Vosges or other less high mountains where roads actually go OVER the mountains instead of IN BETWEEN them. The Alps are on everyone's bucket list (mine too, I am going to Austria in September), But no matter where you stay, you will always have some doubles in your routes.
                            Andrew Vaughan
                            Andrew Vaughan
                            Andrew Vaughan
                            Thank you
                            Kudee
                            Kudee
                            Erdna
                            Erdna
                            Andrew Vaughan
                            Andrew Vaughan
                            • Map lock
                              tfdahazellgmail.com
                              tfdahazellgmail.com
                            • Beta abonnement
                              BMW1300GSA
                              BMW1300GSA
                              2.3k
                              Gerard van der Veer
                              Gerard van der Veer
                            • Uitnodiging
                              Hans Kremers
                              Hans Kremers
                            • SilverFox Controller C2
