  4. normal behavior or is it a problem?
4 Posts 3 Posters 905 Views 2 Watching
  • Aiello antonino
    I would like to understand in your opinion if this is a problem or is it normal behavior? I created this itinerary with Here maps, I sent it to a friend and when he uploads it to MRA NAVIGATION, it tells him that the itinerary was created with OPENSTREETMAP maps, as you can see from the video, this is not true, I have I tried to do the same thing, send me the GPX file, upload it to MyRoute-app NAVIGATION and I get the same warning, is this normal, or is it a bug?
    I leave you the link to the video
    https://youtu.be/qASpWH5_v18?si=RTPChuvMeOCgbT9B
      @Aiello-antonino, A GPX file contains no map data. If you open a GPX like this in the MRA app, it cannot know on which map it was based during planning. When you open a GPX file, it is first displayed on the OSM map. Then if you start navigation, it obviously thinks it was planned on the OSM.
      I understand the confusion. I think a GPX import defaults to OSM in the app. Downloading the GPX is not the best way to open a route in the app. You better use the Routes menu which was intended for that purpose.
        @Con-Hennekens exactly - the GPX file doesn’t know what source was used. Therefore we default to showing the warning.
        @Aiello-antonino the warning can be turned off from the navigation functional settings if you are annoyed by it 🙂
        Aiello antonino 1 Reply Last reply
          @Corjan-Meijerink Understood! Thank you!
