  4. Map problem with here Garmin
8 Posts 6 Posters 2.5k Views 2 Watching
  • Manfred Schiess
    Manfred Schiess
    Manfred Schiess
    This route should go from point 10 to 15 and not make the turn, hoa can i provide the esxtra round? This is on "here garmin map" on "tom tom map" it works .
    Any idea?
    Thanks
    TorqueRider nomko 2 Replies Last reply
    • Manfred Schiess Manfred Schiess
      Any idea?
      Thanks
      @Manfred-Schiess
      Have you already tried whether "disable seasonal closures" in the toolkit has an influence on this?
      Have you already looked with Streetview to see what a possible obstacle could cause?
      Have you already enabled the "Trafic" map layer to see if a possible cause is found?
        Any idea?
        Thanks
        Banned
        @Manfred-Schiess
        Can you provide us with a link to that route so we can check it ourself?
        And i agree with the comments of @Jack-van-Tilburg
        • TorqueRider TorqueRider
          @Manfred-Schiess
          Reinhard-32
          Reinhard-32
          Reinhard-32
          @Jack-van-Tilburg That is the reason. Disable seasonal closure and it works.
          Kindly regards
          Reinhard
          Montana 700i and Mac
          • Mzokk
            I have found several instances with Here maps that the map tiling creates a gap in the road i.e the road exists but when the map tile is created it does not line up. This causes all sorts of routing issues. Ponga.jpg
            Had to create a small "off road" section in basecamp to get the Zumo XT to route past the break
            • Mzokk
              wrote on last edited by Mzokk
              Reported the issue to Here and it was fixed. But not in the Garmin release of the mapping......yet.
              • Manfred Schiess
                Manfred Schiess
                Manfred Schiess
                Thanks for your answers,
                It was the seasonale closure that forced this error. The queation is "is that route really closed at this time?" I didnt find informations on closures. Here is the link to the route.
                Thank you all, see you on road
                https://www.myrouteapp.com/route/open/779048
                  @Manfred-Schiess said in Map problem with here Garmin:
                  But isn't that easy to find on the WWW?
                  Here for example: Wintersperren und Verkehrslage Alpenpässe
                  Reinhard-32
                  Reinhard-32
                  Manfred Schiess
                  Manfred Schiess
                  • Real-time traffic
                    Andy Nicholson
                    Andy Nicholson
                  • HERE map not calibrated
                  • Myrouteappstay
                  • Navigatie met DMD tablet
                  • Show on the maps's button
