  4. Map problem with here Garmin
8 Posts 6 Posters 1.2k Views 2 Watching
  • Manfred Schiessundefined Offline
    Manfred Schiess
    This route should go from point 10 to 15 and not make the turn, hoa can i provide the esxtra round? This is on "here garmin map" on "tom tom map" it works .
    Any idea?
    Thanks
    Jack van Tilburgundefined Nomko Nomdenundefined 2 Replies Last reply
    • Manfred Schiessundefined Manfred Schiess
      Any idea?
      Thanks
      Jack van Tilburg
      @Manfred-Schiess
      Have you already tried whether "disable seasonal closures" in the toolkit has an influence on this?
      Have you already looked with Streetview to see what a possible obstacle could cause?
      Have you already enabled the "Trafic" map layer to see if a possible cause is found?
      Reinhard-32undefined 1 Reply Last reply
        Any idea?
        Thanks
        Nomko Nomdenundefined Offline
        Nomko Nomden
        @Manfred-Schiess
        Can you provide us with a link to that route so we can check it ourself?
        And i agree with the comments of @Jack-van-Tilburg
        | MRA Gold Member |
        | MRA Next + Kawasaki Z650 |
          @Manfred-Schiess
          Reinhard-32undefined Offline
          Reinhard-32
          @Jack-van-Tilburg That is the reason. Disable seasonal closure and it works.
          Kindly regards
          Reinhard
          • Mzokkundefined Offline
            I have found several instances with Here maps that the map tiling creates a gap in the road i.e the road exists but when the map tile is created it does not line up. This causes all sorts of routing issues. Ponga.jpg
            Had to create a small "off road" section in basecamp to get the Zumo XT to route past the break
              wrote on last edited by Mzokk
              Reported the issue to Here and it was fixed. But not in the Garmin release of the mapping......yet.
                Manfred Schiess
                Thanks for your answers,
                It was the seasonale closure that forced this error. The queation is "is that route really closed at this time?" I didnt find informations on closures. Here is the link to the route.
                Thank you all, see you on road
                https://www.myrouteapp.com/route/open/779048
                  Jack van Tilburg
                  @Manfred-Schiess said in Map problem with here Garmin:
                  But isn't that easy to find on the WWW?
                  Here for example: Wintersperren und Verkehrslage Alpenpässe
                  Nomko Nomden
                  Manfred Schiess
                  Mzokkundefined
                  Reinhard-32
                  Jack van Tilburg
                    Arjan de Vriesundefined
                    Arjan de Vries
                  • Unable to login using Apple creds
                  • Problema Car play
                    Jan 50undefined
                    Jan 50
                    1.8k
                  • Adjusting start point surrounding routes
                  • Moving Map does not work with CP
                    Huibertusundefined
                    Huibertus
                  • Embedded Routes
                    Tony Edwards 0undefined
                    Tony Edwards 0
                  • New group for MyRoute-app users on DMD2 systems
                    1.4k
                  • these days very slow to calculate routes
