  4. Here kaart lelijk en traag
29 Posts 13 Posters 10.3k Views 3 Watching
  • Dikke Wim Dikke Wim
    @Lynchy67
    I do exactly the same.
    In my experience it is in between 30-40 kmh. specially in the UK on narrow roads without a view.
    I'm curious, what is your average speed on those roads?
    Lynchy67 Offline
    Lynchy67 Offline
    Lynchy67
    #21
    @Dikke-Wim
    My speed on the Country Lanes is based on how far I can see ahead.
    In the UK many of these Country Lanes are set to 60 mph but I rarely reach that speed unless it is a straight road.
    There are far to many hazards on the country lanes!
    :Horses (I always stop and switch off the engine), Walkers (I slow down), Dogs not on leads (I Stop), blind bends, boy racers, Cyclists, delivery vans and my favourite is Suicidal Pheasants!
    Snapshot 02-02-2024 08:52.jpeg
    Snapshot 02-02-2024 08:51.jpeg
    Corjan Meijerink Jack van Tilburg 2 Replies Last reply
    • Lynchy67 Lynchy67
      @Dikke-Wim
      Corjan Meijerink Offline
      @Lynchy67 Hahaha, thanks for sharing that!
      And as @nick-carthew would add: trees fallen over and blocking your path πŸ˜‰
      • Lynchy67 Lynchy67
        @Dikke-Wim
        Jack van Tilburg Offline
        Jack van Tilburg
        wrote on last edited by Jack van Tilburg
        #23
        @Lynchy67 said in Here kaart lelijk en traag:
        Country Lanes are set to 60 mph.....
        Yes, and then I think; how??? πŸ€” πŸ˜‰
        • Jack van Tilburg Jack van Tilburg
          Well it is not a minimum speed is it πŸ˜‰
          Jack van Tilburg 1 Reply Last reply
            Jack van Tilburg
            you surprise me
            If only I knew that sooner.
            • pieter v Offline
              pieter v Offline
              pieter v
              wrote on last edited by pieter v
              #26
              Ja, inderdaad. Vandaag route gemaakt en here kaarten laden zeer traag
              • hvdv hvdv
                @smuiger
                Klopt, is inderdaad een Here dingetje. Persoonlijk leg ik er de OSM kaartlaar overheen
                Bart Geerts Offline
                Bart Geerts Offline
                Bart Geerts
                @MRA-C Hoe doe je dat? een OSM kaartlaag er overheen leggen? ik kan niet vinden waar en hoe ik dat moet doen.
                alvast bedankt voor de reply!
                Jack van Tilburg nomko 2 Replies Last reply
                • Bart Geerts Bart Geerts
                  Jack van Tilburg
                  #28
                  @Bart-Geerts
                  Op het icoontje rechtsboven in de getoonde kaart klikken (dus niet in een menu). En dan kun je kiezen tussen verschillende kaarten.
                  Handleiding kaartlagen
                    nomko Offline
                    nomko Offline
                    wrote on last edited by nomko
                    #29
                    @Bart-Geerts said in Here kaart lelijk en traag:
                    In deze menu tem selecteer je de standaard kaart lay-out:
                    En met de knop zoals met de rode pijl in de screenshot aangegeven selecteer je de overlay kaart:
                    En zoals je kan zien in de laatste screenshot heb ik nu de HERE kaart als standaard kaart lay-out en gebruik ik de OpenStreetMap kaart als overlay kaart.
                    Let wel op:
                    Het kan gebeuren dat de route die je aanmaakt op een HERE kaart kan afwijken van bv de OpenStreetMap kaart. Dan moet je bv denken aan dat op de HERE map de routelijn precies over de wegen valt die je hebt geselecteerd, maar op de OSM kaart/overlay dat de routelijn er net naast ligt. Niks van aantrekken, de kaart die als standaard is ingesteld is leidend hierin.
                    Dit heb ik wel eens meegemaakt met het maken/aanpassen van routes op bepaalde stukken dat alles netjes staat op de HERE kaart, maar als ik dan OSM inschakel als overlay, dat de route dan net naast de weg valt (in de berm zeg maar).
                    Hieronder zie je een voorbeeld van hoe de ene kaart de andere kaart niet volgt qua route:
                    | MRA Gold Member |
                    | MRA Next + Kawasaki Z650 |
                    Dikke Wim
                    Dikke Wim
                    Jack van Tilburg
                    Jack van Tilburg
                    hvdv
                    hvdv
                    pieter v
                    pieter v
                    Drabslab
                    Drabslab
                    Lynchy67
                    Lynchy67
                    smuiger
                    smuiger
                    Bart Geerts
                    Bart Geerts
                    • HERE maps updates
                      12.3k
                      Alfred Schrittwieser
                      1.4k
                    • Route maken in TomTom kaart en vervolgens met de app navigeren
                      Bruno 7
                      Bruno 7
