  4. Map display delayed (4.0.7 -239 / Android 12)
24 Posts 4 Posters 404 Views 4 Watching
  • ValléeDesFées
    ValléeDesFées
    ValléeDesFées
    wrote on last edited by ValléeDesFées
    Since last update to 4.0.7 - 239, the position where you are, displayed on the map has been delayed. Even with 'legal' speeds, you are about 200 meters ahead of the displayed position on the map. (both with a preloaded route navigation as from A to B navigation)
    U changed the settings from the map from 'detailed' to 'basic' view and there is an improvement. So it seems to be, for some reasons the app takes too many resources from the phone (DMD665).
    It appeared when upgraded the MRA app to the latest Beta.
    KTM 890 Adventure | DMD T665 | MRA/DMD2
    • ValléeDesFées ValléeDesFées
      @Raymond-Valk this is a known problem with the Here maps being worked on by Here. Some people have found that running a GPS program such as a speedo in the background vastly corrects the issue.
      ValléeDesFées 1 Reply Last reply
        ValléeDesFées
        ValléeDesFées
        ValléeDesFées
        @Doug-Robinson will give it a try and let you know, probably next week I can test live...
          ValléeDesFées
          ValléeDesFées
          ValléeDesFées
          @Doug Robinson - I Ran Flitsmeister on the background when the issue appeared.
          After switching off the Flitsmeister app I had te same behaviour
          • ValléeDesFées
            ValléeDesFées
            ValléeDesFées
            @Doug-Robinson I installed the Speedometer app and ran it in the background. Yesterday it worked flawless ... today it was delayed again, restarted the phone, ran the Speedometer app again and restarted the route, same issue.
            I checked the speedometer app and it is accurate, Waze, Google maps, worked both fine and really accurate.
            Any ideas?
              Any ideas?
              ValléeDesFées
              ValléeDesFées
              ValléeDesFées
              @Corjan-Meijerink - enig idee wanneer dit opgelost gaat worden? Lees dat dit ook al langer speelt en dit zie ik niet als een bug maar als een BUG. want de app wordt zo nagenoeg onbruikbaar als het issue zich voordoet.
                @ValléeDesFées het probleem is voor veel mensen gelukkig al opgelost.
                Enkele Android toestellen vertonen soms nog wel problemen.
                De oorzaak van het nu bekende probleem wordt door HERE opgelost en zou als het goed is gedurende Q1 2024 moeten worden opgelost. Ik zit dus ook geduldig en vol spanning te wachten op elke update van hun 😉
                CD130 1 Reply Last reply
                  @Corjan-Meijerink als je een keer naar @ValléeDesFées zijn Android toestel wil kijken kan je hem heel makkelijk lokken met een dubbele espresso. Dit heb je niet van mij 😋 Weet niet of je zelf over een toestel beschikt om deze big te simuleren.
                  • CD130 CD130
                    ValléeDesFées
                    ValléeDesFées
                    ValléeDesFées
                    @CD130 en @Corjan-Meijerink
                    Inderdaad ... ik woon in de buurt en een dubbele espresso gaat er wel in
                      Je bent sowieso meestal welkom! 🙂
                      Mocht je eens langs willen komen, stuur gerust een berichtje.
                      Wanneer we bericht hebben dat HERE verbeteringen heeft doorgevoerd kan je dit via de bestaande test methodes testen!
                        ValléeDesFées
                        ValléeDesFées
                        ValléeDesFées
                        @Corjan-Meijerink - ik hou het forum in de gaten!
                          ValléeDesFées
                          ValléeDesFées
                          ValléeDesFées
                          @ValléeDesFées said in Map display delayed (4.0.7 -239 / Android 12):
                          Hoi @Corjan-Meijerink zijn er al ontwikkelingen vanuit Here?
                            @ValléeDesFées donderdag heb ik mn maandelijkse overleg met hun ontwikkelaars!
                            ValléeDesFées RetiredWingMan 2 Replies Last reply
                              ValléeDesFées
                              ValléeDesFées
                              ValléeDesFées
                              @Corjan-Meijerink Ik ben benieuwd ...
                                @Corjan-Meijerink is there an update available from your meeting with Here?
                                • ValléeDesFées ValléeDesFées referenced this topic on
                                  ValléeDesFées
                                  ValléeDesFées
                                  ValléeDesFées
                                  @RetiredWingMan said in Map display delayed (4.0.7 -239 / Android 12):
                                  @Corjan-Meijerink - any update yet? I see in this topic:
                                  https://forum.myrouteapp.com/topic/6136/beeldscherm-hapert-en-loopt-achter
                                  that somebody has the same issues and an update will be available this week, is that related to the issue described in this topic too?
                                    Work on this issue continues the coming days! 🙂
                                    ValléeDesFées 2 Replies Last reply
                                      ValléeDesFées
                                      ValléeDesFées
                                      ValléeDesFées
                                      @Corjan-Meijerink said in Map display delayed (4.0.7 -239 / Android 12):
                                      Thanks for the update @Corjan-Meijerink - we're curious!
                                        ValléeDesFées
                                        ValléeDesFées
                                        ValléeDesFées
                                        Hi Corona, is this issue fixed In the announced mega update from the 21st?
                                        CD130 Corjan Meijerink 2 Replies Last reply
                                          @ValléeDesFées “Corona”? 😅😂😂😂
                                          ValléeDesFées
                                          ValléeDesFées
                                          • Help please, new user
                                            Bull Tahr
                                            Bull Tahr
                                          • My Routeapp Stays questions
