  4. "Add stop" option missing from the menu...
5 Posts 2 Posters 1.5k Views 2 Watching
  • LennyO
    I have a Gold lifetime membership, I see "Gold" and "Navigation" in my profile.
    When I create a route on my Android, start navigating, press "..." in the bottom right corner, the menu comes up and the options are:
    • Stop navigation
    • Turn voice prompts off
    • Turn audio warnings on
      etc,...
      but I do not have "Add stop" below "Stop navigation"...
      Why so????
      Thanks!
    • LennyO LennyO
      • Stop navigation
        etc,...
        Why so????
        Thanks!
      @Lenny-O add stop is only available while navigating a route (rather than track).
      So either load a route or generate a fastest route 🙂
      Curvy routes are navigated using track navigation.
      LennyO 2 Replies Last reply
        @Corjan-Meijerink I have created a new route. Not a track.
        I just watched the Webinar where "add stop" was present....
        I am confused...
          @Corjan-Meijerink Oh.... I see what you are saying....
          Yes, mine was "curvy".
          So, it's pretty bad that you can't add a stop to a "curvy" road. What is I need gas?
          Also, how can you change the route from curvy to fastest?
          Thanks!
          • LennyO LennyO
            Thanks!
            @Lenny-O that’s something we are working on 🙂
            If you want the fastest route, simply select the “straight” option.
            • BĂ©ta to no-bĂ©ta
