  4. Message to stop navigation
9 Posts 5 Posters 2.0k Views 3 Watching
  • Corrado Miniati
    Sometimes it happened to me that without activating the device, the wording "stop navigation - Confirm?" appears.
    Why does this happen?
    Thanks a lot
    • Corrado Miniati Corrado Miniati
      Thanks a lot
      @Corrado-Miniati-0 How did you mount your phone? Is it possible that vibrations are causing something to be activated, making your phone think you've pressed a button?
      Corrado Miniati 1 Reply Last reply
        Hi Rob, thanks for the feedback.
        The tablet is mounted on a sturdy RAM arm, it works very well.
        This is the first time this has happened to me, I don't think it depends on the vibrations.
          @Corrado-Miniati-0 I don't like the Ram mount because the arms tend to interfere with the side buttons, I've changed to the Quadlock with vibration dampner. It works much better and I can switch easily between portrait and landscape. As for your issue, it is likely that something has initiated closing the app.
            @Doug-Robinson
            Hi Douglas and thanks for feedback, I use an 8" tablet and can't use the quadlock mount.
            The tablet's RAM cradle does not hide any buttons and you can activate whatever you want.
            Something definitely started the browsing shutdown, I'd like to find out the cause.
              The only cause is you pressing stop navigation or the Android back button. Most likely the last happened due to vibrations / the mount 🙂
                Hi Corjan,
                I didn't touch any buttons because I was driving but the road was perfectly paved and there were no vibrations.
                It's the first time this has happened, on other roads with much more vibrations it had never happened, very strange....
                  Hi Corjan,
                  @Corrado-Miniati-0, Like with your flyer symbol going off screen, this could be due to a dirty screen. Clean it thoroughly. A defect hardware back key could indeed also be the problem.
                    thanks a lot, i will try to clean it.
