  4. Stromverbrauch viel zu hoch!
23 Posts 8 Posters 10.9k Views 3 Watching
    @hawebo exactly! Thanks for confirming this 🙂
    The root cause really is originating from the HERE map rendering. Quite frustrating.
    @Corjan-Meijerink Just for your info, the change in the last SDK appears to have made the power consumption problem very much worse for me with no change in my installation setup and/or use. With the previous SDK, my Google 6 Pro would slowly charge up to 100% and that is why the last change in version to 4.0.6 232 (with SDK change) appears to have drastically changed the power consumption for the worse with me losing 80% of my battery over 4 hours whilst charging yesterday. Other nav apps allow the battery to charge on the same setup. Thought this might help with feedback to HERE and to maybe help you.
    Ducati Multistrada V4 Rally
    iPhone 18 Pro
    CHIGEE AIO-6 LTE
    • hawebo hawebo
      @Corjan-Meijerink said in Stromverbrauch viel zu hoch!:
      Könnte MRA in dem Fall nicht erwägen, auf die Kartendarstellung von TomTom zu wechseln?
      Damit wäre die Planung von kurven- bzw höhenreichen Routen einfach und keine anschließende Übertragung/Speicherung nach HERE mehr erforderlich.
      @hawebo said in Stromverbrauch viel zu hoch!:
      Scroll up to the awnser of Corjan 👆
      HERE is the only map provider that supports the Flutter design platform. Since this app is being developed on that platform, it is not possible to choose another map provider for the navigation engine.
      Drabslab 1 Reply Last reply
        Drabslab
        Drabslab
        Drabslab
        @Rob-Verhoeff i understand. I also understand that i cannot use Next until this problem is solved.
        • Rob Verhoeff Rob Verhoeff referenced this topic on
        Drabslab
        Drabslab
        hawebo
        hawebo
        • Startpunt wijzigen
          Ad V
          Ad V
          Ed van Klink
          Ed van Klink
        • Vrienden toevoegen
