  4. Default map
Default map
5 Posts 5 Posters 1.9k Views 3 Watching
  • iain.gardengmail.com
    Why is it that you cannot choose your preferred default route map format for new and existing routes to open in? I like planning routes in Google maps format, but every time I load a map, even one I completed in Google format, I have to change it from Here format first (ok, but not the one I usually want to use). It's very annoying. I am aware that the system doesn't use Google maps to calculate routes, but I don't see why there cannot be a system setting to default to your preferred format.
    • iain.gardengmail.com iain.gardengmail.com
      @iain-gardengmail-com
      You can do that, open a route, go to the drop-down list where the 3 maps are selectable and choose the map that you want as the default map
      Stefan Hummelink Rob Verhoeff 2 Replies Last reply
        @Hans-van-de-Ven-MRA-Master I believe TS is talking about the overlays, and not the maps, HERE, TomTom or OSM. The default overlay cannot be adjusted as far as I know.
          @Hans-van-de-Ven-MRA-Master @Stefan-Hummelink yep you're right. The overlay changes with the map you choose. So, OSM, TomTom or Here.
            @Stefan-Hummelink said in Default map:
            No, it cannot indeed.
            @Rob-Verhoeff said in Default map:
            Not sure what you mean, but the chosen overlay does not stick when you change maps. You will need to choose the desired overlay again after switching maps.
            • MyRoute-app offline
              54.5k
            • Hiya from UK
            • route bug
              toni ccc
              toni ccc
            • Route with one Waypoint cannot be saved
            • Maps Michelin
