  4. Issue importing GPX file from Garmin Tread
7 Posts 5 Posters 3.3k Views 3 Watching
  • Chris Peltz
    Chris Peltz
    Chris Peltz
    wrote on last edited by Chris Peltz
    The attached gpx, generated from Garmin Tread, does not import into MRA. I continue to get an error:
    Something went wrong
    while uploading your file.
    MyRoute-app couldn't read your file.
    Anyone have any idea what part of the file may be incompatible with the format MRA is expecting?
    GPX File
    Stanisław HABVEN aka MrMRA 2 Replies Last reply
    • Chris Peltz Chris Peltz
      GPX File
      wrote on last edited by Stanisław
      @Chris-Peltz try to import it as a route-track
      and then use-edit imported track, it went quite fine on my side:
      Regards
      Staszek
      Chris Peltz 1 Reply Last reply
      • Stanisław Stanisław
        Chris Peltz
        Chris Peltz
        Chris Peltz
        @Stanisław I tried using that option, but I got the exact same error. Must be some other configuration I have set wrong.
        • Chris Peltz
          Chris Peltz
          Chris Peltz
          Ok. I figured out the bug. If I try to upload the file by pointing to my Google Drive, it barfs. When I download to my local folders on my phone and then upload it, the import works fine.
            GPX File
            @Chris-Peltz
            Just like Garmin's Explore website, the Tread-App does not handle routes well, you then get a so-called "direct route". If you want to use a created route on your XT2, use the connector on the MRA Website. If you want to use the Tread-App as a means of transport for your routes, only use the track. These, together with the route and waypoint, are also transferred via the connector and appear in the Tread app and Explore website after communication from the XT2 to the Tread app / Explore website. In the Tread-app / Explore website you can then provide the waypoints with a different icon which is shown in the XT2.
            Note: For the XT users, the Garmin Drive app handles the routes well.
            • Rob Verhoeff
              @Chris-Peltz @Hans-van-de-Ven-MRA-Master It is not smart to address one subject in two different topics.
              The other topic: https://forum.myrouteapp.com/topic/5326/issue-importing-a-gpx-file-from-garmin-tread
                @Rob-Verhoeff I have deleted the other topic. There was nothing useful in it.
                @Chris-Peltz Please be mindful about posting duplicate topics.
                Chris Peltz
                Chris Peltz
