  4. Description field for route-tracks
3 Posts 2 Posters 930 Views
  • martin-phogel.de Offline
    martin-phogel.de
    Apparently there is only a description field for routes in the "Route Information", but not for route-tracks.
    And when saving a route (GPX1.1 and GPX 1.2), the <rte> contains the <desc> but the <trk> does not.
    Is there a particular reason for this distinction?
      martin-phogel.de
      OK, let me put it this way:
      I would appreciate an improvement in the "Description" field:
      1. within MRA a description should also be available for route-tracks, not only for routes.
      2. when importing a GPX file, an existing <desc> should be taken over, both when importing as route and as route-track
      3. when saving a route as a GPX file (1.1 or 1.2), an existing description should also be created for <trk> as <desc>, not only for <rte> - and accordingly when saving a route-track.
      I would prefer to save my trips within MRA as route-tracks instead of routes and would like to use a track for further processing outside MRA, so these extensions would be helpful.
      • Corjan Meijerink Offline
        Thanks for the idea! 🙂
        martin-phogel.de
        martin-phogel.de
        • Interesting behaviour on a pre-planned route that uses the same road in both directions
        • Onbegrijpelijke afslagen
        • Stemgeluid sterker bij afspelen muziek
        • GPX1.2 & Garmin Tread
          MTC-Zeilberg
          MTC-Zeilberg
          Huibertus
          Huibertus
        • POI naming/text display
