  4. GPX route transfer to Zumo XT not working
27 Posts 6 Posters 15.2k Views 2 Watching
  • Don Stauffer
    Don Stauffer
    Don Stauffer
    wrote on last edited by Don Stauffer
    I've been a happy user of MRA for a couple of years. I have a Zumo XT on my BMW. My standard process is to build a route in MRA on my PC, then open the route in the Android app on my phone. I then download the GPX file, and open it in Garmin Drive App. When the phone is connected to the Zumo, the Drive app transfers the track and route to the GPS.
    That's all been good for some time. Recently, the GPX transfer from the Drive app to the Zumo has been failing. The track is transferred, but the route is not, and the Zumo reports that the import failed. I've tried GPX 1.0, 1.1 and 1.2.
    The transfer is successful if I use a USB cable from the PC to the Zumo.
    This was a problem some time ago with the Drive app, but it was fixed by Garmin. I have not intentionally updated the app. I am using Drive app version 4.22.19.
    I know other users are following the same basic procedure to load routes to the Garmin. Anyone else having problems recently?
    Thanks in advance.
    • Don Stauffer Don Stauffer
      Thanks in advance.
      @Don-Stauffer I had the same problem. Solution. Remove thé drive app from your phone and then install it again.
      Reconnect your XT voilà problem solved.
      Don Stauffer 1 Reply Last reply
        Don Stauffer
        Don Stauffer
        Don Stauffer
        @Marinus-van-Deudekom Thanks for the suggestion, Marinus. I deleted and re-installed the Drive app. New version is unchanged, 4.22.19.
        But the results did not change, the Zumo receives the track, but the route import fails.
        I'll check on some of the Zumo forums, and I am considering building a route in Basecamp as a test.
          @Don-Stauffer I had to register the new installed Drive app with my username and password. After that the drive connected again with my XT.
          When I export the gpx 1.1 I press on download and then open it directly with the drive app.
          That should do the trick
          If that doesn't work maybe @Hans-van-de-Ven-MRA-Master had a solution
          HABVEN aka MrMRA MTC-Zeilberg 3 Replies Last reply
            I'll test it sometime today
              MTC-Zeilberg
              MTC-Zeilberg
              MTC-Zeilberg
              Just tested with a Samsung S22 and the XT.
              Just work, both the routes and the tracks are sent and received.
                @Marinus-van-Deudekom and @Don-Stauffer
                As MTC-Zeilberg indicates, it just works, both the route and the track are sent and received.
                  Thanks in advance.
                  @Don-Stauffer, My guess is that you nare using the wrong GPX 1.1 format, there are two. You need this one:
                  instead of this one:
                    @Hans-van-de-Ven-MRA-Master Mine works
                    Don's doesn't
                      Don's doesn't
                      Don Stauffer
                      Don Stauffer
                      Don Stauffer
                      @Marinus-van-Deudekom I have already tried GPX 1.0, 1.1 and 1.2.
                      I did re-enter my Garmin username and password when I re-installed the Drive app.
                      This is a procedure I have done many times with no issues. I have changed phones recently, the current phone is a Pixel 6a. I am considering testing on the old phone.
                      Thanks for the testing and suggestions.
                      -dhs
                        -dhs
                        Don Stauffer
                        Don Stauffer
                        Don Stauffer
                        Well, Playstore states that my old Moto phone is not compatible with Garmin Drive. Interesting, as I had it installed before resetting the phone.
                        The Drive app is connecting to my Pixel phone to the Zumo, and the Drive app icon is visible on the Zumo. As stated, the tracks transfer properly, but the route fails, similar error on all three GPX flavors.
                        • MTC-Zeilberg MTC-Zeilberg
                          Don Stauffer
                          Don Stauffer
                          Don Stauffer
                          @MTC-Zeilberg Thanks for testing, could you let me know which version of the Drive app you were using? My installed version is 4.19.22
                          The Zumo XT software version is 6.50.
                          Marinus van Deudekom HABVEN aka MrMRA 2 Replies Last reply
                            @Don-Stauffer Drive app is 4,22,19
                            Yours 4.19.22 typo?
                              Yours 4.19.22 typo?
                              Don Stauffer
                              Don Stauffer
                              Don Stauffer
                              @Marinus-van-Deudekom Sorry, that was a typo. Installed version is 4.22.19, so no difference there. Last time I had this issue it was related to a particular version of the Drive app.
                                @Don-Stauffer
                                4.22.19
                                  @Don-Stauffer
                                  4.22.19
                                  Don Stauffer
                                  Don Stauffer
                                  Don Stauffer
                                  @Hans-van-de-Ven-MRA-Master Since I had nothing else indicated, I deleted and re-installed the MRA app on my phone. No change, Zumo reports 'failed to import new trips'.
                                  I opened the MRA site from the web browser on the phone, opened last route, dowloaded, open with Garmin Drive. Same result, tracks were imported, route was not.
                                  I switched to my Samsung tablet. I opened the Drive app, connected to the Zumo. I used the browser to open the MRA site, logged in to my account. I opened 'last route', saved it, opened with the Drive app. Selected 'send to Zumo'. Zumo reports tracks added, failed to import new trips.
                                  Not sure where to go from here.
                                    @Don-Stauffer
                                    When you go to trips on the XT and choose import via the menu?
                                      @Don-Stauffer
                                      Don Stauffer
                                      Don Stauffer
                                      Don Stauffer
                                      @Hans-van-de-Ven-MRA-Master The new route does not appear on the list in the 'Trip Planner' on the XT. I see previous routes that I have transferred, but I think the process is failing before that point.
                                      I'm getting the same failure using two different devices. The same version of the Drive app works for others. Opening the file using the App or the website (is there a difference?) produces the same error. A hard-wire (USB) transfer does work from my Desktop using the MRA website and Connector app. Tracks do transfer properly.
                                      The only thing I can think of is a hard reset of the Zumo. The software reports as up to date. I can re-import my saved locations using the Garmin Explore website, so it will not be too inconvenient.
                                      Thanks!
                                        Thanks!
                                        @Don-Stauffer
                                        Can you share the url of the route? Make sure it is set public
                                          @Don-Stauffer
                                          Don Stauffer
                                          Don Stauffer
                                          Don Stauffer
                                          @Hans-van-de-Ven-MRA-Master Certainly.
                                          https://www.myrouteapp.com/en/social/route/7863171?mode=share
                                          Thanks for your time and attention!
                                          Don Stauffer
                                          Don Stauffer
                                          MTC-Zeilberg
                                          MTC-Zeilberg
