  4. Problems with MRA Navigation using Apple CarPlay
4 Posts 2 Posters 90 Views 1 Watching
  • Ad V Offline
    Ad V Offline
    Ad V
    I use MRA Navigation via Apple CarPlay on my Honda Goldwing screen. Great, if it would always work. The problems:
    1. After a break the app doesn’t find my position anymore. No other solution than to restart the route
    2. Starting a route from the middle, e.g. if the app didn’t continue correctly after a break, you should be able to jump the first (hard) waypoint (the start of the route) and then the app should jump all other waypoints that you have already passed. This works sometimes but often not. Very frustrating if your riding in a group and are depending on your navigation.
      Is there a way to “jump into” a route from a chosen waypoint?
    • Ad V Ad V
      Rob Verhoeff Offline
      @Ad-V said in Problems with MRA Navigation using Apple CarPlay:
      Yes there is: longpress the waypoint from were you want to resume the route.
      Ad V 1 Reply Last reply
        Ad V Offline
        Ad V Offline
        Ad V
        @Rob-Verhoeff Geweldig: bedankt. Weet je ook hoe dit werkt op een no touch CarPlay scherm? Lang induwen kan dan niet
        • Ad V Ad V
          @Ad-V Nee, CarPlay is nog in ontwikkeling en erg basic. Kijk eens op de nieuwe website. Daar worden alle onderdelen helder uitgelegd en lees je ook bij CarPlay en Android Auto wat nu je verwachtingen moeten zijn!
          Ad V
          Ad V
            Thomas Schäfer
            Thomas Schäfer
            Kobutex Motorreizen
            Kobutex Motorreizen
          • Seizoen sluitingen wegen
          • App loopt vast
            Marcel Schreurs
            Marcel Schreurs
          • I can't see Road Closures
            KeesV
            KeesV
            Sytze van der Laan
            Sytze van der Laan
