  4. Problems with MRA Navigation using Apple CarPlay
4 Posts 2 Posters 90 Views 1 Watching
  • Ad V
    Ad V
    Ad V
    I use MRA Navigation via Apple CarPlay on my Honda Goldwing screen. Great, if it would always work. The problems:
    1. After a break the app doesn’t find my position anymore. No other solution than to restart the route
    2. Starting a route from the middle, e.g. if the app didn’t continue correctly after a break, you should be able to jump the first (hard) waypoint (the start of the route) and then the app should jump all other waypoints that you have already passed. This works sometimes but often not. Very frustrating if your riding in a group and are depending on your navigation.
      Is there a way to “jump into” a route from a chosen waypoint?
    • Ad V Ad V
      @Ad-V said in Problems with MRA Navigation using Apple CarPlay:
      Yes there is: longpress the waypoint from were you want to resume the route.
      Ad V 1 Reply Last reply
        Ad V
        Ad V
        Ad V
        @Rob-Verhoeff Geweldig: bedankt. Weet je ook hoe dit werkt op een no touch CarPlay scherm? Lang induwen kan dan niet
        • Ad V Ad V
          @Ad-V Nee, CarPlay is nog in ontwikkeling en erg basic. Kijk eens op de nieuwe website. Daar worden alle onderdelen helder uitgelegd en lees je ook bij CarPlay en Android Auto wat nu je verwachtingen moeten zijn!
          Ad V
          Ad V
          • Strange translation
            martin-phogel.de
            martin-phogel.de
            11.0k
          • Undo/Redo tool is hidden
          • Shared toggle switch
          • Crazy routing
