  4. Very very small issue: textbox
12 Posts 8 Posters 136 Views 1 Watching
  • Robin 11
    Robin 11
    Robin 11
    Textbox
    Nick Carthew Corjan Meijerink RetiredWingMan 3 Replies Last reply
    • Robin 11 Robin 11
      Textbox
      @Robin-11 Have you increased the size of the text on your phone?
      My text and buttons look smaller.
      Robin 11 1 Reply Last reply
        Robin 11
        Robin 11
        Robin 11
        @Nick-Carthew Tried changing the textsize in Android settings, but didn't change the textsize in the app. Or is there an option in the app itself to change the size of text?
        • Robin 11 Robin 11
          Textbox
          @Robin-11 what phone are you using? We need to rework some UI parts to support lower resolutions
            Robin 11
            Robin 11
            Robin 11
            @Corjan-Meijerink Samsung Galaxy S21
            • Robin 11 Robin 11
              Textbox
              @Robin-11 my Samsung S7 does the same. Resolution is 1920x1080. Default font style. Screen zoom set to middle. Font size set to 30%.
                @Doug-Robinson changing font size, screen zoom or resolution did not make any difference.
                  @Doug-Robinson correct, that won’t help - need to fix within the app 🙂
                    @Corjan-Meijerink, It is not so much the resolution, but the aspect that is playing part here.
                    My CAT has way less resolution, but does not show this problem, where my Huawei does, despite having 1.5 times more pixels in width.
                      Same on iPhone X, but instead of using "Navigate", just use "YES" it is shorter, will fit and says the same. (you use No already, so should work with Yes)
                      • richtea999
                        'Go!' would also work, I think.
                        • richtea999 richtea999
                          @richtea999 Will be fixed in the next update 😉
                          Robin 11
                          Robin 11
                            Axel Lange
                            Axel Lange
                          • In het kort......
                          • Route probleem
                            Jack 13
                            Jack 13
