  4. Very very small issue: textbox
12 Posts 8 Posters 136 Views 1 Watching
  • Robin 11undefined Offline
    Robin 11
    Textbox
    Nick Carthewundefined Corjan Meijerinkundefined RetiredWingManundefined 3 Replies Last reply
    • Robin 11undefined Robin 11
      Textbox
      @Robin-11 Have you increased the size of the text on your phone?
      My text and buttons look smaller.
      Robin 11undefined 1 Reply Last reply
        Robin 11
        @Nick-Carthew Tried changing the textsize in Android settings, but didn't change the textsize in the app. Or is there an option in the app itself to change the size of text?
          Textbox
          @Robin-11 what phone are you using? We need to rework some UI parts to support lower resolutions
            Robin 11
            @Corjan-Meijerink Samsung Galaxy S21
              Textbox
              @Robin-11 my Samsung S7 does the same. Resolution is 1920x1080. Default font style. Screen zoom set to middle. Font size set to 30%.
                @Doug-Robinson changing font size, screen zoom or resolution did not make any difference.
                  @Doug-Robinson correct, that won’t help - need to fix within the app 🙂
                    @Corjan-Meijerink, It is not so much the resolution, but the aspect that is playing part here.
                    My CAT has way less resolution, but does not show this problem, where my Huawei does, despite having 1.5 times more pixels in width.
                    • Jörgenundefined Offline
                      Same on iPhone X, but instead of using "Navigate", just use "YES" it is shorter, will fit and says the same. (you use No already, so should work with Yes)
                      iPhone 12 pro (iOS 180.2)
                      Oukitel RT3 (Andr. 12)
                      Samsung XCover 4 (Andr. 9 Pie)
                      For more information, (Workshops) click here
                      • richtea999undefined Offline
                        'Go!' would also work, I think.
                          @richtea999 Will be fixed in the next update 😉
                          🏍️ Motorcycle: DMD-T665 + SilverFox controller
                          richtea999undefined
                          Robin 11undefined
                          Robin 11
                          • Rijtijden verschillen
                            Lex.Kloet.RXundefined
                            Lex.Kloet.RX
                          • Data usage
                            stuart marrittundefined
                            stuart marritt
                          • Route Planner and Twisty routes
                            Maarten vundefined
                            Maarten v
