  3. Adding route points and dragging them
route pointsshaping routedragging points
3 Posts 2 Posters 1.5k Views
  • Corné Voogt
    Corné Voogt
    Corné Voogt
    wrote on last edited by Corné Voogt
    MRA Next 3.2.15
    When making a route on Iphone I want to add route shaping points between A and B.
    Problem 1. In the app adding a route point on an existing route with the intention of dragging it to another road in order to shape the route, MRA numbers this route point as the LAST number of the route, thus the end point.
    This is very annoying since I have to switch to route point view every-time and manually place it in the sequence after the previous point where it wanted it in the first place.
    Please allow numbering after the previous point.
    2. On Iphone the last route point is right at the bottom of the screen. Trying to drag the last points up doesn’t work since the whole app is then dragged up making that impossible.
    Then I have to drag all above point down to get the sequence I want.
    Please add a blank space of one route point high at the bottom to allow for dragging up without moving the whole app screen.
    • Nick Carthew Nick Carthew moved this topic from [App-Beta] Problems, Bugs and other Issues on
    • Nick Carthew
      Moved from the BETA test forum.
      • Corné Voogt Corné Voogt
        MRA Next 3.2.15
        @Corné-Voogt Do not use the Place waypoint button.
        If you double tap the screen it will place a new route point in the correct order. This takes a little practice.
        Corné Voogt
        Corné Voogt
        • Suggestion: Club folder permission attributes
          Anonymouse
          Anonymouse
        • Minimap
