  3. Printing Waypoints
Printing Waypoints
6 Posts 3 Posters 2.3k Views 1 Watching
  • Chris Tremain
    Chris Tremain
    Chris Tremain
    Is it possible to be able to print out the list of waypoints and the time/mileage info ??
    It would be really handy when planning a bigger trip to be able to see on a single page ideal points for stops and overnights
    Many thanks
    • Reinhard-32
      Reinhard-32
      Reinhard-32
      Yes, it is possible. You have two options.
      First: make a screenshot.
      Second: when the route is open go to page menue and select safe as .pdf.
      Kindly regards
      Reinhard
      Montana 700i and Mac
      • Chris Tremain Chris Tremain
        Many thanks
        @Chris-Tremain As @Reinhard-32 said, choose save as and then select .PDF. If you use a coloured route point for your stops, you can add a note to the route point that can be read in the .PDF file. 33EC12AE-E613-44F2-A27D-E158AC813C7B.png
        Chris Tremain 2 Replies Last reply
          Chris Tremain
          Chris Tremain
          Chris Tremain
          @Nick-Carthew
          forgot to say 'thank you !!'
            Chris Tremain
            Chris Tremain
            Chris Tremain
            @Nick-Carthew
            Also - just realised I am comparing your John O'Groates route with mine
            Getting into how to add the POI's on the route - can you tell me, where you have some of the poi's just off the route - does the satnav ignore them if you don't cross over them
            I assume the show just as a waypoint ??
              @Nick-Carthew
              @Chris-Tremain It depends on whether you add the POI as a waypoint or POI. If you add as a waypoint your route will try to navigate to it whereas if it’s added as a POI it’ll just be as a visual marker on your satnav.
              Reinhard-32
              Reinhard-32
              Chris Tremain
              Chris Tremain
              • Kaart niet zichtbaar
              • Xpert overlay not clear
                Corrado Miniati 0
                Corrado Miniati 0
              • Google maps
                Ed Bos 0
                Ed Bos 0
              • Trains like Ferries?
                Corrado Miniati 0
                Corrado Miniati 0
